MrRetroGamer Posted February 18, 2004 Share Posted February 18, 2004 I'm trying to help someone troubleshoot a dead port #1 on a 4 port console using a known good controller, with no response of any kind. No bent pins on the port from a visual inspection. What is the best way to help them figure out if it's only that port that is dead or if it's a bigger problem like a POKEY or GTIA chip? They do not have access to a diag cart or any other special equipment. Thanks Quote Link to comment Share on other sites More sharing options...
jsoper Posted February 18, 2004 Share Posted February 18, 2004 I'd replace the 4052 IC first, those go out a lot, and you can't start a game without it. They're socketed on some motherboards, otherwise you need to: clip the pins unsolder and pull the pins out one by one clean out the holes with solder wick install a dip socket and shiny new 4052. If that doesn't start the game, you need to check the bigger chips. Quote Link to comment Share on other sites More sharing options...
classics Posted February 18, 2004 Share Posted February 18, 2004 Is there any analog response, or keypad response? Quote Link to comment Share on other sites More sharing options...
