Rocko Posted February 18, 2004 Share Posted February 18, 2004 What is a good one that runs in XP? I have distilla, but when I try to run it the window pops up and it says something, but then it closes down faster than I can read it. Maybe you could help me. Quote Link to comment Share on other sites More sharing options...
Inky Posted February 18, 2004 Share Posted February 18, 2004 What is a good one that runs in XP? I have distilla, but when I try to run it the window pops up and it says something, but then it closes down faster than I can read it. Maybe you could help me. Did you try running Distella in 98 compatibility mode? Quote Link to comment Share on other sites More sharing options...
Starman Posted February 18, 2004 Share Posted February 18, 2004 You have to run it from the command prompt. Mike Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted February 18, 2004 Share Posted February 18, 2004 Distella is a command line tool, it sounds like you are just double clicking on it from Windows Explorer. Go to Start / Run, and type in "cmd". That will bring up a command prompt window. Navigate to the directory you have it installed in, and run it from there. EDIT: If you're unfamiliar with using the command prompt, I'd be happy to give you more detailed info. Just post and let me know. AM Quote Link to comment Share on other sites More sharing options...
Inky Posted February 18, 2004 Share Posted February 18, 2004 Distella is a command line tool, it sounds like you are just double clicking on it from Windows Explorer. Go to Start / Run, and type in "cmd". That will bring up a command prompt window. Navigate to the directory you have it installed in, and run it from there. EDIT: If you're unfamiliar with using the command prompt, I'd be happy to give you more detailed info. Just post and let me know. AM Duh! I forgot that. Quote Link to comment Share on other sites More sharing options...
Rocko Posted February 18, 2004 Author Share Posted February 18, 2004 I am a bit familiar with command prompt, but I could use a refresher course. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted February 18, 2004 Share Posted February 18, 2004 I am a bit familiar with command prompt, but I could use a refresher course. Ok, No problem. I'll write this as if you are a Windows and Command line newbie, don't take offense if I cover a few things you already know how to do. I assume you've downloaded Distella already. You can use Windows Explorer to create a folder for it, I'd just create a folder called "Distella" on your C: Drive, and copy the executable file there. To do that, open explorer, highlight the C Drive in the left pane, then right click anwyhere in the white space on the right pane, choose "New" and "Folder" from the popup menu. Also, copy the binary file of the game that you want to disassemble to the same directory. For the purpose of this explanation, I call that file "game.bin". At this point, when you look at the "Distella" folder you created on the C Drive, you should see at least two files in there, distella.exe and game.bin. Now, open the command prompt. You should see something like this: Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:WINDOWSsystem32>_ Type in (without the quotes) "CDDistella" ... CD stands for Change Directory. You should now see something like this: Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:WINDOWSsystem32>CDDistella C:Distella_ Now we're ready to dissasemble the game you previously copied into the C:Distella directory. Type in the following (again, without the quotes): "distella -pafs game.bin > game.txt" You should now see something like this: Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:WINDOWSsystem32>CDDistella C:Distelladistella -pafs game.bin > game.txt PASS 1 PASS 2 PASS 3 C:Distella_ If you see the PASS 1, 2, & 3, you sucessfully disassembled the game, and there will now be a new file in the C:Distella directory called "game.txt". If you want to open it from the command line, just type in: "notepad game.txt", which will open windows notepad and allow you to view and edit the file. Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:WINDOWSsystem32>CDDistella C:Distelladistella -pafs game.bin > game.txt PASS 1 PASS 2 PASS 3 C:Distellanotepad game.txt Hope this helps! AM Quote Link to comment Share on other sites More sharing options...
Rocko Posted February 18, 2004 Author Share Posted February 18, 2004 When I type CDdistella it brings up this: C:Distella> When I follow the rest, it does not show the C:Distelladistella -pafs game.bin > game.txt PASS 1 PASS 2 PASS 3 C:Distella_ does the BIN file have to be titled "Game"? Quote Link to comment Share on other sites More sharing options...
Rocko Posted February 18, 2004 Author Share Posted February 18, 2004 and when I open the txt file it gives me this: Error: .bin file must be 2048 or 4096 bytes Quote Link to comment Share on other sites More sharing options...
NE146 Posted February 18, 2004 Share Posted February 18, 2004 Sounds like you're trying to dissassemble a game larger than 4k ...which is a whole other subject Quote Link to comment Share on other sites More sharing options...
Rocko Posted February 18, 2004 Author Share Posted February 18, 2004 Sounds like you're trying to dissassemble a game larger than 4k ...which is a whole other subject So how do I dissasemble a game over 4K? Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted February 18, 2004 Share Posted February 18, 2004 Ah, yes, I forgot to mention that you can only disassemble games that are 4K or smaller with Distella. There is a way to split an 8K file into 2 for a disassembly, but I've neve attempted it and I think it's probably above the beginner level. As far as the file being named "game.bin", no that's not important, just make sure it's a valid 2600 binary file, and it ends with the extension ".bin". You mention that you never got the "PASS 1, PASS 2, PASS 3", did you get an error message on the screen, or did it just do nothing? I need a little more info to be of any more help. AM Quote Link to comment Share on other sites More sharing options...
Rocko Posted February 18, 2004 Author Share Posted February 18, 2004 You mention that you never got the "PASS 1, PASS 2, PASS 3", did you get an error message on the screen, or did it just do nothing? I need a little more info to be of any more help. AM It went back to: Distella> So how do I split it up into two games? Quote Link to comment Share on other sites More sharing options...
NE146 Posted February 18, 2004 Share Posted February 18, 2004 So how do I dissasemble a game over 4K? Thomas often-referred-to post to the rescue! http://www.atariage.com/forums/viewtopic.php?t=3214 Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted February 18, 2004 Share Posted February 18, 2004 I'm searching right now for the thread about splitting 8K files for disassembly, and I can't seem to find it. I'll keep looking and post a link when I find it. Like I said, I've never done it so I can't give you instructions based on my personal experience. Quote Link to comment Share on other sites More sharing options...
NE146 Posted February 18, 2004 Share Posted February 18, 2004 Ah, yes, I forgot to mention that you can only disassemble games that are 4K or smaller with Distella. There is a way to split an 8K file into 2 for a disassembly, but I've neve attempted it and I think it's probably above the beginner level. As far as the file being named "game.bin", no that's not important, just make sure it's a valid 2600 binary file, and it ends with the extension ".bin". You mention that you never got the "PASS 1, PASS 2, PASS 3", did you get an error message on the screen, or did it just do nothing? I need a little more info to be of any more help. AM He just got an error message because it never dissasembled anything. Easy. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted February 18, 2004 Share Posted February 18, 2004 NE146! You beat me to it. Thanks. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted February 18, 2004 Share Posted February 18, 2004 He just got an error message because it never dissasembled anything. Oh yeah, of course. I knew that. Quote Link to comment Share on other sites More sharing options...
NE146 Posted February 18, 2004 Share Posted February 18, 2004 But yeah.. that is a little above Beginner level. Kepone, you should just start with 2k-4k games first to get a feel. Atari-Maximus' instructions above are very good Quote Link to comment Share on other sites More sharing options...
Rocko Posted February 18, 2004 Author Share Posted February 18, 2004 Yeesh. Can anyone just get the bmx part out of california games? I have a version here and all I really need is the bmx part. Quote Link to comment Share on other sites More sharing options...
Rocko Posted February 18, 2004 Author Share Posted February 18, 2004 But yeah.. that is a little above Beginner level. Kepone, you should just start with 2k-4k games first to get a feel. Atari-Maximus' instructions above are very good It is reptone, Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted February 18, 2004 Share Posted February 18, 2004 Can anyone just get the bmx part out of california games? Hmm... I wouldn't be able to do that for you easily, maybe someone with a little more knowledge about 8K disassembly could help you out. You can still change graphics with Hack-O-Matic on 8K & up games. AM Quote Link to comment Share on other sites More sharing options...
Rocko Posted February 18, 2004 Author Share Posted February 18, 2004 I know, I just need to change some colors. I have already changed the graphics. Quote Link to comment Share on other sites More sharing options...
NE146 Posted February 18, 2004 Share Posted February 18, 2004 But yeah.. that is a little above Beginner level. Kepone, you should just start with 2k-4k games first to get a feel. Atari-Maximus' instructions above are very good It is reptone, DOH! Sorry sometimes I just type a little too fast Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted February 18, 2004 Share Posted February 18, 2004 I know, I just need to change some colors. I have already changed the graphics. Yeah, I kind of figured that was the case. Sorry I can't be of any more help...I always stick to hacking the smaller games. AM Quote Link to comment Share on other sites More sharing options...
