Rocko Posted February 24, 2004 Share Posted February 24, 2004 Is there a special way to remove carts from the 7800? It is really tight on mine, and I dont want to break it. Quote Link to comment Share on other sites More sharing options...
Rocko Posted February 24, 2004 Author Share Posted February 24, 2004 Also, do the sticks (on the controllers) move alot, or are they somewhat stationary? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted February 25, 2004 Share Posted February 25, 2004 A lot of the later 7800s have a slightly smaller cart slot. Usually after frequent use it will start getting better as the plastic will start wearing down a bit. I suppose you could take some fine sandpaper and speed up the process a bit. Also, some 7800s have the motherboard at a bad angle, you can correct this by opening up the case and putting something (like a small peice of cardboard or plastic) under the back two edges of the motherboard where it hits the case. You want to get it raised up enough that the cart slot on the motherboard lines up with the cart slot on the case. Mitch Quote Link to comment Share on other sites More sharing options...
