PickAxePete Posted March 19, 2004 Share Posted March 19, 2004 Has anyone taken apart their Namco Joystick? My action button "popped" and the response isn't that effective anymore. There are no screws and I'm afraid of breaking the plastic. Quote Link to comment Share on other sites More sharing options...
sku_u Posted March 19, 2004 Share Posted March 19, 2004 Post some pics. Some may be able to figure it out by looking at the top and underside. If there are no screws of any kind, it may be glued together. Quote Link to comment Share on other sites More sharing options...
bjk7382 Posted March 19, 2004 Share Posted March 19, 2004 watch for screw holes under stickers or rubber feet. Quote Link to comment Share on other sites More sharing options...
PickAxePete Posted March 19, 2004 Author Share Posted March 19, 2004 there are none. I looked in and about the battery port and around the entire unit. Nothing. There are four little rubber feet that were glued to the bottom. I thought about screws possibly being under them, but I know someone here did rip open his Joystick and I would like to confirm they are under the rubber feet b/4 I go ripping them off. I peeled one back a bit and did not see anything, but I may just have to rip the whole foot off to tell. Quote Link to comment Share on other sites More sharing options...
NE146 Posted March 19, 2004 Share Posted March 19, 2004 Someone on these boards already modified one of them.. if you do a search you might find it <edit> Never mind.. found it. It was Rob Mitchell http://www.atariage.com/forums/viewtopic.php?t=44435 Quote Link to comment Share on other sites More sharing options...
PickAxePete Posted March 19, 2004 Author Share Posted March 19, 2004 thanks, I'll print the thread and check it out when I get home. Quote Link to comment Share on other sites More sharing options...
PickAxePete Posted March 20, 2004 Author Share Posted March 20, 2004 I printed the disassembly page and it was really helpful, but I foolishly spent way too much time trying to unscrew the screws for the fire button manually, when I should've taken my electric drill out for it right away. After removing the fire plate, I noticed the coil spring had just popped out of place. So I put it back in place, tested it, and it seems fine. So I'm about to test it so I switch the power on and it doesn't go on. Apparently the black battery wire disconnected during my tedious disassembly. My problem is, I can't figure out where to solder it back. I've tried touching possible locations but nosign of life. Now I'm bummed. Quote Link to comment Share on other sites More sharing options...
