hopeful Posted August 23, 2001 Share Posted August 23, 2001 I tried to used my 4 port 5200 after many years of being stored in the basement. When I turned on the power switch the tv screen turned orange. Any suggestions...I'm really hoping that this machine is still useable. Quote Link to comment Share on other sites More sharing options...
Gunstar Posted August 23, 2001 Share Posted August 23, 2001 Assuming you had a cartridge plugged in when you did this, it's probably a case of dirty connectors on the cartridge and/or where it plugs in on the 5200. When these systems sit around for awhile, especially with the controllers, the metal contacts get tarnished, just like silverware or anything else. A good cleaning with a pencil eraser and then a good cleaning with some rubbing alcohol and a Q-tip should do the trick (if corrosion/tarnish is the problem). Personally, I would give the whole system a thorough cleaning, getting all the dust and stuff cleaned out of the unit with a vaccum or one of those cans of pressurized keyboard cleaner, I just saw this stuff at Walmart next to cdr's and other disks and cables in the electronics department. I bet it works fine after these steps are taken... Quote Link to comment Share on other sites More sharing options...
hopeful Posted August 24, 2001 Author Share Posted August 24, 2001 Thanks we'll give it a try. We've opened up the 5200 and it was very dusty so hopefully the cleaning will do the trick! Quote Link to comment Share on other sites More sharing options...
