pongstroid Posted April 22, 2004 Share Posted April 22, 2004 Anybody in the SF Bay Area (Oakland) who knows there way around these machines? Quote Link to comment Share on other sites More sharing options...
Cassidy Nolen Posted April 23, 2004 Share Posted April 23, 2004 What exactly is it doing? I do not know anyone "arcade" that far north in CA, but we may be able to help you here...all vectors share some common problems. Cassidy Quote Link to comment Share on other sites More sharing options...
pongstroid Posted April 23, 2004 Author Share Posted April 23, 2004 A few years ago I had a friend put in a new cap kit for the monitor. Worked fine for about 10 hours of play. Last time I had the machine on for a round, I noticed an electrical smell and a small bit of black wispy smoke coming out the top of the machine. (Likely something on the monitor board.) I quickly turned it off, and haven't turned it on for 3 years now. Then I have a few other projects for the machine. It came with two other boards: Major Havoc and Quantum. Which explains why the former owner, an Atari employee, had installed a trackball on the control panel. I've also purchased a Space Duel board. So, I've got a few other projects too: 1) Repair/replace the trackball. The current one doesn't move freely. 2) Create a control panel adapter so I can easily play one player Space Duel on the Gravitar controls. Better yet would be to get a Space Duel cp to swap in. 3) Create a control panel adapter for Quantum. 4) Create a control panel adapter for Major Havoc. Any help is appreciated! Cheers... Quote Link to comment Share on other sites More sharing options...
Cassidy Nolen Posted April 23, 2004 Share Posted April 23, 2004 That is quite a piece you have there! Vector monitors have come a long way. Its pricey, but its a permanent fix. I would suggest doing both deflection and high voltage boards if you plan on keeping the machine (which I am sure you do): http://arcadeshop.com/parts.htm#Monitors I am assuming its a standard Wells Gardner 6100 monitor (I think all the Atari 19 inches were, IIRC it was the 25 inches that were Amplifone?). Check out http://arcadeshop.com/parts.htm#Trackball and you can get all the bearing parts you need. No sense in buying a new trackball. As for the connectors, no ideas there. If you feel comfortable enough taking on the monitor, I think you could handle that part. I know the harnesses are similar, but you may have a bit of trouble with a 'one-size-fits-all' plug. HTH at least some. Cassidy Quote Link to comment Share on other sites More sharing options...
pongstroid Posted April 23, 2004 Author Share Posted April 23, 2004 That is quite a piece you have there! Yeah - and got it for $50! Was driving back work and the machine was sitting out on a driveway for sale. I passed it, went home - and then had second thoughts. They still had it so I picked it up. It was a terribly nice suprise to open up the back and see the two other boards in there! I am assuming its a standard Wells Gardner 6100 monitor (I think all the Atari 19 inches were, IIRC it was the 25 inches that were Amplifone?). I believe it is the 19 Wells Gardner. Check out http://arcadeshop.com/parts.htm#Trackball and you can get all the bearing parts you need. No sense in buying a new trackball. That's perfect - will have to do that. This sort of stuff wasn't easily available 5 or 6 years ago. As for the connectors, no ideas there. If you feel comfortable enough taking on the monitor, I think you could handle that part. I'm not sure if I'm comfortable - my soldering skills are essentially from 25 years ago putting together little Radio Shack kids kits. I've no testing equipment, so I'm really not to sure how qualified I am to work on the board. I know the harnesses are similar, but you may have a bit of trouble with a 'one-size-fits-all' plug. That's my theory at least. I'm not sure how practical it is to make simple adapters. I looked a bit when I first got the machine, but couldn't easily find the parts I *thought* I needed. Quote Link to comment Share on other sites More sharing options...
