sabeen557 Posted May 27, 2004 Share Posted May 27, 2004 is the power supply on the 7800 the same as the 2600, also what kind of cable does it need to connect to a tv Quote Link to comment Share on other sites More sharing options...
oesii Posted May 27, 2004 Share Posted May 27, 2004 different power supply, you can find other answers in the 7800 FAQ: http://www.atariage.com/7800/faq/index.htm...l?SystemID=7800 all the atari systems on top have a FAQ. Quote Link to comment Share on other sites More sharing options...
Max-T Posted May 28, 2004 Share Posted May 28, 2004 Here's a direct link to the part of the 7800 FAQ you are looking for: http://www.atariage.com/7800/faq/index.htm...mID=7800#cat1_2 Best of luck! Quote Link to comment Share on other sites More sharing options...
Rob Mitchell Posted May 29, 2004 Share Posted May 29, 2004 The power requirements are 12 volts, 1 amp. I have modifed my 7800 console to use a generic power supply. The cable to the TV is the standard RCA type to Antenna in on Channel 2 or 3. Rob Mitchell, Atlanta, GA Quote Link to comment Share on other sites More sharing options...
+Mitch Posted May 29, 2004 Share Posted May 29, 2004 The power requirements are 12 volts, 1 amp. I have modifed my 7800 console to use a generic power supply. Actually, it's 9V 1A. Mitch Quote Link to comment Share on other sites More sharing options...
Rob Mitchell Posted May 29, 2004 Share Posted May 29, 2004 The power requirements are 12 volts, 1 amp. I have modifed my 7800 console to use a generic power supply. Actually, it's 9V 1A. Mitch Ugh .. Thanks! Rob Mitchell, Atlanta, GA Quote Link to comment Share on other sites More sharing options...
