pmpddytim Posted May 28, 2004 Share Posted May 28, 2004 I am working on a small project, mostly 'cause I like tinkering around with stuff but also because I think it will be usefull. I am going to make a cart adaptor so that I dont have to force the carts that are a tight fit for a 6 switch in my 6 switch. I don't want to tear apart a perfectly good 2600 just for the cart connector. Is there anyplace that sells these or is there an alternative? Or does anyone have a shot 2600 they would sell me the cart connector from? Thank you. -Tim Quote Link to comment Share on other sites More sharing options...
Susuwatari Posted May 29, 2004 Share Posted May 29, 2004 Although 2600 uses standard 12/24 pin card edge connector with 0.1" spacing, it's the tab for opening dust flap that isn't standard. You will need to sacrifice a 2600 to get the flap part and don't try a 2600jr, the tabs are part of the case and not the cart connector. Quote Link to comment Share on other sites More sharing options...
pmpddytim Posted May 29, 2004 Author Share Posted May 29, 2004 No sacrifice needed on my part. "da'Wiz" as he apparently wishes to be called, hooked me up. -Tim Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted May 29, 2004 Share Posted May 29, 2004 "da'Wiz" as he apparently wishes to be called LMAO, that was a wordplay on DA-BULLS. Can't beat free. It's a proper cart slot with tabs btw.! Quote Link to comment Share on other sites More sharing options...
pmpddytim Posted May 29, 2004 Author Share Posted May 29, 2004 "da'Wiz" as he apparently wishes to be called LMAO, that was a wordplay on DA-BULLS. I figured as much. But I think from now on you shall simply be known as "da Wiz" (at least to me). -Tim Quote Link to comment Share on other sites More sharing options...
