madblownaway Posted May 29, 2004 Share Posted May 29, 2004 Is there a way I can plug both of these to an av output, I know how to do just the genesis but not both. Quote Link to comment Share on other sites More sharing options...
AtariYoungin Posted May 30, 2004 Share Posted May 30, 2004 The Genesis outputs to the CD and the CD to the TV, or maybe thats backwards...it is 2 AM....all I know is you need a cable to link the 2 systems together, and then its one vid output for the 2 Quote Link to comment Share on other sites More sharing options...
Rockin' Kat Posted May 30, 2004 Share Posted May 30, 2004 erm... which model Genesis and Sega CD do you have? If you have a model 1 Genesis, you will need to get a stereo mini plug cable to go from the front headphones jack on the Genesis to the mix port on the back of whichever model Sega CD you have and then take the audio from the stereo RCA outputs on the back of the Sega CD unit. If you have a Model 2 Genesis and a Model 2 Sega CD, then the audio mixing is done throught the expantion port and all you need to do is use hook the AV cable to the back of the Genesis as both the Genesis's sound and the Sega CD's sound will be coming from there, mixed together. Quote Link to comment Share on other sites More sharing options...
madblownaway Posted May 30, 2004 Author Share Posted May 30, 2004 Model 1....and thanks very much Quote Link to comment Share on other sites More sharing options...
madblownaway Posted May 30, 2004 Author Share Posted May 30, 2004 there a certain size stereo cable??? Quote Link to comment Share on other sites More sharing options...
