Wrathchild Posted June 3, 2004 Share Posted June 3, 2004 Hi, I have a basic program, the football manager game 'Liverpool', that I have on tape. I've loaded this onto my real Atari and it works. However, when running the game with DOS loaded it doesn't work due to the memory loss of using DOS. However it was OK to both 'save' an 'list' the file to disk. I can make an image of this disk using my PC, but can I then somehow extract and turn the .bas file into a CAS file that could then be loaded into an emulator using CLOAD? Thanks, Mark Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted June 3, 2004 Author Share Posted June 3, 2004 It looks like XEX2CAS is the software I can use, I'll let you know how I get on with it tonight. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted June 4, 2004 Author Share Posted June 4, 2004 Dammit! I've misplaced my 10502PC cable Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted June 4, 2004 Share Posted June 4, 2004 well, there once was a type-in listing in Analog or antic - for exactly this purpose. You boot an Autorun.SYS file and convert the tape to disk (using CLOAd to load the Basic file from tape and then CSAVE to save to disk, yes disk!). Loading the disk then is also quite easy: boot the disk with Basic, when the READY prompt appears, type in CLOAD and press RETURN (you will notice, that the program loads very fast from disk not from tape)... This program can also be used to transfer files from various DOS versions... Well, I have the program in my collection - so e-mail me if you are interested. I will return a zipped ATR image with the program file(s) and some docs to get you going... -Andreas Magenheimer. P.S.: email amp#abbuc*de Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted June 4, 2004 Author Share Posted June 4, 2004 Well, I located the right box in the loft and so here's the file. Use the CAS file in an emulator with Basic enabled - it needed the SIO patch left on. Boot up to the READY prompt and type CLOAD and then ENTER twice. When the READY prompt returns, type RUN to play. The ATR is included, but as mentioned I don't think you can't play from disk. Not a bad game as it goes... may be worth setting up the teams for the next season Regards, Mark liverpool.zip Quote Link to comment Share on other sites More sharing options...
