US games carts
ATARIPITBULL
Is there a rarity differance between the flat US game carts like this Gopher & the beveled end ones like this Picnic?
Not much, AFAIK. I seem to run into one type about as often as the other.
The plain carts came before the beveled ones, right?
I've never seen NTG is a plain case, and I'm under the impression that it was one of (if not the) last US Games releases.
Also, Eli's Ladder, which was apparently made with leftover US Games inventory, only exists in a beveled case, hinting that the company didn't have any plain cases left . . .
From my experience, the beveled cases are slightly more common, but probably not enough to affect rankings,
  • 18 years later...
Bumping a really old post because I have the same question and can't find a definitive answer. I had originally thought the beveled cases were first and then they switched to standard to reduce costs. Then I saw that games which were only released in standard have lower product numbers than games which were only released in beveled, pointing to the opposite being true. Now I'm just discovering that there are more variations than I thought existed (e.g. standard case Piece O' Cake) so I'm wondering if anyone knows 100% for sure which came first.
Could be that both cart versions were made for every white box U.S. Games title, although I've never seen a beveled Squeeze Box and I've never seen a square Picnic, Piece O' Cake or Entombed.
Keir, can you show me a picture or scan of a square cartridge version of Piece O' Cake?
8)
Edited by Rom Hunter
On 1/29/2023 at 10:50 AM, Keir said:
...so I'm wondering if anyone knows 100% for sure which came first.
The standard cases came first, as evidenced by the fact that the black label Vidtec games used them.
The beveled cases were the same ones used by Amiga for Mogul Maniac and Off Your Rocker.  This is no coincidence, as both Amiga and U.S. Games were located in Santa Clara, CA.  Obviously, there was a connection there that resulted in both using the same suppliers.  The Color Bar Generator by VideoSoft and Eli's Ladder by Simage also used that style of case.
1 hour ago, Rom Hunter said:
Keir, can you show me a picture or scan of a square cartridge version of Piece O'Cake?
Here’s a link to an eBay auction that @Psionic posted in another thread: https://www.ebay.com/itm/255896281401
55 minutes ago, Psionic said:
The standard cases came first, as evidenced by the fact that the black label Vidtec games used them.  The beveled cases were the same ones used by Amiga for Mogul Maniac and Off Your Rocker.  This is no coincidence, as both Amiga and U.S. Games were located in Santa Clara, CA.  Obviously, there was a connection there that resulted in both using the same suppliers.
That makes sense. Seems like everything points to standard then beveled.
