Adonick Posted July 6, 2004 Share Posted July 6, 2004 Hey all, I managed to get my Atari 2600 Jr (long rainbow) working, but it comes in clear only if you press the outgoing RCA cord up, like prop a cart underneath the plug near where it plugs into the unit. Any idea whether this is the cord or the port, and if it is the port, how I might go about fixing it? Yours, Nick Quote Link to comment Share on other sites More sharing options...
jr2084 Posted July 7, 2004 Share Posted July 7, 2004 It could possibly be a broken connection Quote Link to comment Share on other sites More sharing options...
hex65000 Posted July 7, 2004 Share Posted July 7, 2004 Agreed. It sounds like you have a bad connection somewhere. Check the solder joints on your RF out, but check your cable first. It'll be easier to check and you may not have to pull apart your deck. Hex. [ Back to work... ] Quote Link to comment Share on other sites More sharing options...
Blinky Posted July 15, 2004 Share Posted July 15, 2004 If the cable comes off easy. Then it is probably the RCA connector. I had the same problem with mine. I used a very small screwdriver the same kind you can use to open-up a watch. You need to bend the two half round metal tabs inside the RCA connector a little. I had my Jr already opened up for a VDO MOD so I did it at the back side of the RCA connector where the tabs are easier to access. But you might try it first at the front of the RCA connector without opening your Jr first. Shine a bright light into the RCA connector and look for the half round tabs at each side. Bend them a little at the top of each tab where you can see the (white) plastic. Quote Link to comment Share on other sites More sharing options...
