JesterDev Posted July 18, 2004 Share Posted July 18, 2004 I got DASM (DOS) working under wine. I was searching for a few hours before I tried for a Linux port. So anyway I just wanted to mention this since I know a few people where looking for a Linux port since the source (at least for me) does not compile without errors. The command line usage is: wine -- dasm.exe filename.asm -lkernel.txt -f3 -v5 -ofilename.bin The only difference from DOS is the '--' which is required by wine in order to send command line arguments to DASM (or any other program). Quote Link to comment Share on other sites More sharing options...
Happy_Dude Posted July 18, 2004 Share Posted July 18, 2004 http://www.biglist.com/lists/stella/archiv...3/msg00295.html This source patch posted on [stella] worked great for me. Makes DASM 2.20.07 compile into a working binary There was talk about having it included in the main distribution but I don't know what happened there. Quote Link to comment Share on other sites More sharing options...
JesterDev Posted July 19, 2004 Author Share Posted July 19, 2004 I emailed you last night about that patch But my mail server is down now.. Anyway, I tried that patch and get errors. That attachment just shows up as plain text so I made a file named dasm.patch ran the proper commands, and I get this: patching file src/Makefile Hunk #1 FAILED at 7. 1 out of 1 hunk FAILED -- saving rejects to file src/Makefile.rej patching file src/asm.h Same thing that happened last night.. So I guess I'm back to using wine unless you happent to have a copy of the actual file? I don't know if that will make a difference or not but I thought it would be worth a try. I tried to patch the correct version. And when I try and compile I get tons ands tons of errors. I'm not that great with C but I tried to fix them with no luck. Running Suse 9.1 Pro. Quote Link to comment Share on other sites More sharing options...
Happy_Dude Posted July 19, 2004 Share Posted July 19, 2004 in the post he says there will be compile errors but it still compiles and works. Been a long time since I used the patch but I'll see if I can find it. Quote Link to comment Share on other sites More sharing options...
Happy_Dude Posted July 19, 2004 Share Posted July 19, 2004 dasm.patch.gz Quote Link to comment Share on other sites More sharing options...
JesterDev Posted July 21, 2004 Author Share Posted July 21, 2004 Thank you! That worked perfectly. Well save for all the warnings.. Quote Link to comment Share on other sites More sharing options...
