WSUCougars Posted August 23, 2004 Share Posted August 23, 2004 Hi All, This is my first post, but am a long-time reader of these forums. I've recently dusted off/cleaned up and started using my old 2600 (the same one I've had since X-Mas 1982). I have, however, encountered one small problem. My joysticks (two EPYX 500XJs) seem to be interfering with the video signal to the TV. Whenever I move the stick, or click the fire button, I get static on the monitor, which gets worse the more rapidly I move the device. Just to make sure that it wasn't the EPYX sticks, I tried a working Sega Genesis pad as well, and although the problem is far less visible it's still there. Has anyone else encountered a similar issue? For the record, my system is a 4-switch woodgrain with no modifications and all of the original parts. Everything else seems to work ok (aside from a slightly fuzzy picture), but I would appreciate any suggestions on what I might try. Thank you very much in advance. - Kris Quote Link to comment Share on other sites More sharing options...
doubledown Posted August 23, 2004 Share Posted August 23, 2004 If it hasn't been used in a while I would say a thorough cleaning would be in order. Are you using a TV/Game switch, or a RF Coaxial adapter. The TV/Game switch could be a big problem. Not to mention how dirty the cartrdige slot may be. Quote Link to comment Share on other sites More sharing options...
WSUCougars Posted August 23, 2004 Author Share Posted August 23, 2004 Thanks for the quick reply. Yes, I am using a manual RF switch (this piece, at least, is new - picked one up at Radioshack for my C64) and not the coax adapter (still need to get one of these). The funny thing is that I tried hooking everything up to a different TV, and while the general noise/static went away, the interference from the controller was still there. Really, it's more of an annoyance than anything. The games are still playable and the color/sound are great, but it would still be nice to take care of this last little issue. And yes, you're right, the whole unit could use a thorough cleaning (more than I've given it already, at least). Again, thanks for your help. - Kris Quote Link to comment Share on other sites More sharing options...
