Skatepunk60 Posted October 20, 2001 Share Posted October 20, 2001 Does it annoy the hell out of you switching back and forth from joysticks to paddles? ME TOO so i came up with a schematic for a switch. plug | 123456 on/off on/off switch switch 123456 123456 connector connector JOYSTICK PADDLE its rough but i think i can make one with an extra system and joystick Quote Link to comment Share on other sites More sharing options...
Skatepunk60 Posted October 20, 2001 Author Share Posted October 20, 2001 it came out wrong it got squished ill try to make another Quote Link to comment Share on other sites More sharing options...
Atari-Jess Posted October 20, 2001 Share Posted October 20, 2001 you do that. Quote Link to comment Share on other sites More sharing options...
Skatepunk60 Posted October 20, 2001 Author Share Posted October 20, 2001 Email me if you wanna see it because i cant put it on here its in paint Quote Link to comment Share on other sites More sharing options...
Genki Posted October 20, 2001 Share Posted October 20, 2001 Actually it's simpler to make one. The paddle uses up (#1) and down (#2) as the fire buttons. You could wire both joysticks and paddle straight through and have a DPDT switch to isolate pin 1 and 2 of the controller ports. Or just have both wired in w/o the switch. Quote Link to comment Share on other sites More sharing options...
Lady Jaye Posted October 20, 2001 Share Posted October 20, 2001 Or you could always use a Coleco Gemini joystick, if you can find one. They're not the best joystick out there, but there is a paddle integrated on the controller, aside from the joystick. Quote Link to comment Share on other sites More sharing options...
Ze_ro Posted October 21, 2001 Share Posted October 21, 2001 quote: Originally posted by Phoenix: Or you could always use a Coleco Gemini joystick, if you can find one. They're not the best joystick out there, but there is a paddle integrated on the controller, aside from the joystick. Only problem with this is that you'll only get one paddle per port... games like Warlords or Street Racer you'll still need a set of normal paddles for if you want multiplayer. --Zero Quote Link to comment Share on other sites More sharing options...
Scott Stilphen Posted October 21, 2001 Share Posted October 21, 2001 Just make a Y-adapter Quote Link to comment Share on other sites More sharing options...
Skatepunk60 Posted October 21, 2001 Author Share Posted October 21, 2001 thats what im goin for but with a switch Quote Link to comment Share on other sites More sharing options...
Scott Stilphen Posted October 22, 2001 Share Posted October 22, 2001 I'm not following the reason for the switch. If you make a 'Y' adapter, you'll have both a joystick and a set of paddles plugged into the same port, and both will work, depending on what game you're playing. Quote Link to comment Share on other sites More sharing options...
Skatepunk60 Posted October 22, 2001 Author Share Posted October 22, 2001 That wound work would it one needs to be turned off so it dont interfere with the other one Quote Link to comment Share on other sites More sharing options...
Genki Posted October 22, 2001 Share Posted October 22, 2001 Interfere? What are you using, Dreamcast controller?? All the switches in Joystick are normally open so unless any of them are pressed the joystick sends nothing to the console. Paddle's fire button are also normally open contacts. And the 2 pots are connected to it's own line so the paddle won't interfere with any joysticks. The only problem with a straight through Y adapter is if you played Astrosmash as it's probably the only game that can use either controllers. Quote Link to comment Share on other sites More sharing options...
Skatepunk60 Posted October 23, 2001 Author Share Posted October 23, 2001 See i just think it would be better with the switch Quote Link to comment Share on other sites More sharing options...
Genki Posted October 23, 2001 Share Posted October 23, 2001 Then you must like Astrosmash. In this case all you'd need is a DPDT switch to toggle pin 1 and 2. Pin 1 and 2 are used for paddle fire 1 and 2 respectively. And the same pin 1 and 2 are used for up and down on joystick. Everything else can be straight though and not have any problem at all. But if you want to throw in a number pad then you may be asking for too much. Quote Link to comment Share on other sites More sharing options...
Skatepunk60 Posted October 23, 2001 Author Share Posted October 23, 2001 Actully its left/right for the buttons (just a little friendly criticizm) but i would like the switch to disconnect the circuit itself to turn that joystick padlle whatever off i wanna make a unit that you can use driving paddles keypads touchpads and controller just plug the two u use the most and flip the switch over to that side YA STILL WITH ME? Quote Link to comment Share on other sites More sharing options...
Genki Posted October 24, 2001 Share Posted October 24, 2001 Ok for an universal Y adapter, you might want to isolate just the VCC and ground (pin 6 and 7). Without power, one controller won't function at all. While most controller used just ground, there are a few that do use VCC. Quote Link to comment Share on other sites More sharing options...
