Charlie_ Posted September 11, 2001 Share Posted September 11, 2001 Is there some sort of issue with the controller ports on coleco gemini systems going bad? The controller will not go up or fire unless i pull up on the plug. I even tried to bend the pins off at a slight angle to make sure all connections were good. It didnt help. Does anyone think i should go ahead and resolder the pins where they meet the board? Charlie Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted September 12, 2001 Author Share Posted September 12, 2001 Well, I thought there was a problem with Gemini systems and the controller ports because all the ebay auctions I have seen say things like: "works but the controller port might need to be cleaned because it doesnt work all the time." I got a Gemini and sure enough the player 1 controller port didnt work well. I had to pull up on the plug to get it to move in all directions. I took the thing apart and played with it for a while and wound up resoldering the pins where they go into the motherboard. All I had to do was touch them with the pen iron. All but one. One I touched and the solder seemed to "reject" the pin and go to the outside radius. I added a little solder to this one. Everything works fine now. Looking at the design it seems that over time plugging and unpluggin joysticks places stress on the solder points. The plastic "D" shell doesnt clip to the mother board to tightly. This is a great little system. It's very small. I don't have a 2600jr (yet) but I wonder if the gemini is any bigger or smaller. So FYI, if you get a gemini with this problem get out the soldering pen. :-) Charlie Quote Link to comment Share on other sites More sharing options...
Atari-Jess Posted October 27, 2001 Share Posted October 27, 2001 this seemed like an ancient(few months old?) post so i wanted to add somethin, i had that same problem before my friend smashed it. (i still have no clue why he did it) Quote Link to comment Share on other sites More sharing options...
Genki Posted October 27, 2001 Share Posted October 27, 2001 BTW the jr is slightly smaller and about an inch shorter than Gemini Quote Link to comment Share on other sites More sharing options...
