birdie3 Posted September 27, 2004 Share Posted September 27, 2004 Does anyone know them? I just scored one of these sweet PONG units and it takes four C cells but I would rather use a power supply. Any help with what power supply to use would be greatly appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted September 27, 2004 Share Posted September 27, 2004 The 4 D cells will give you 6 volts of power, I doubt any more than 750mA to 1Amp would be needed. I can't help as far as plug & polarity. If you are comfortable taking stuff apart, you can do a trace (or better yet, test with a digital volt/ohm meter) from the battery tray to the power plug. Stephen Anderson Quote Link to comment Share on other sites More sharing options...
