Junie Posted November 11, 2001 Share Posted November 11, 2001 Is it possiable to create a simple Y splitter to connect both a joystick and a set of paddles to the player 1 port on the Atari? For example a 9 pin male with two 9 pin females, comming off the 9 pin male. Or if you perfer change the wording to plug and socket.. I personally am looking for something that will allow me to keep a joystick and a set of paddles always connected. Instead of having to chose a game depending on whats currently connected or constantly changing them. If the Y splitter is possiable for two, can the Y splitter be made for 4 or more? Joystick, Paddles, Track Ball, Number Pad, Indy 500 driving controller, etc. Also can this be done exactly the same for the Player 2 port? Junie Quote Link to comment Share on other sites More sharing options...
Atarinvader Posted November 11, 2001 Share Posted November 11, 2001 It should be possible. I think that all the conections on the controller and all the conections on a set of paddels are contected to different pins, and therefor shouldnt interfer with each other. But Im not too sure what would happen with driving controllers or keyboards. [ 11-11-2001: Message edited by: atarinvader ] Quote Link to comment Share on other sites More sharing options...
The Night Phantom Posted November 11, 2001 Share Posted November 11, 2001 N.B. this issue has been previously discussed. Quote Link to comment Share on other sites More sharing options...
Ze_ro Posted November 12, 2001 Share Posted November 12, 2001 I'd still recommend attaching a set of Gemini joysticks, or the joysticks from the Sears Video Arcade 2. They have a functional paddle built into the controller. The only problem is for games that need the second paddle... and the ones that use the second paddle by default (1-player Video Olympics does this). However, if you mostly play one player games, then this works great. --Zero Quote Link to comment Share on other sites More sharing options...
