Junie Posted November 12, 2001 Share Posted November 12, 2001 I just finished creating two extenstion cords for the Atari controllers. They were made with a 9 Pin Male and a 9 Pin Female D-Subminiature connectors. I used some wire I already had, some 22 AWG single strand wire. I actually braided the 9 pieces of wire together, they look almost like one piece of wire. Then I soldered on the connectors, after I used my Digital Multi-Meter to find out where the same wire was on both ends. I finished up my connections by securely wrapping it in electrical tape. I plan to later add the connector housing's, once I get some more cash to give it a more proffesional look and make it a lot more strong. I got the connectors at Radio Shack for $1.49 each. So it cost me $2.98 per joystick extension cable, and some time. The extension cables are about a 1/4" short of 9 feet So now I can play the Atari just about anywhere in my room. 9 feet might be a bit over-kill, but the extension cords work great. I tested them with a Joystick and a set of Paddles. Also I created a simple adapter to allow me to play my Atari on my newer cable ready TV. I didn't feel like paying $7 or more, so I simply made it from parts I already had so it cost me $0. It consists of a coaxial cable cut in half, I use one of the parts, and at the end of it I added a RCA Female jack. I simple stripped the wire and connected and soldered the middle wires together and the other wires. Then I finished it off with electrial tape as well. The Atari to TV cable has to be hooked-up and unhooked to switch between TV and the Atari, but I don't care. Perhaps I'll throw in a small project box and a switch to make it a actual switch box. The image from the Atari seems to be a lot clearly than the image I get from my switch box and older TV. Of course I don't have to turn the dial on my newer TV to fix the sound which is nice I plan to make a Y-adapter so I can have a joystick and a set of paddles always plugged in. My only complaint about the joystick extension cables is that the set of paddles are both laying in bed. Perhaps I'll make a special Y-adapter and split the set of paddles so I can leave one of them by the Atari and the other where every I am playing Anyone have any other Atari cable ideas? Junie Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted November 12, 2001 Share Posted November 12, 2001 You could use a serial-port extension cable as an extension. And the Coleco Gemini controllers have the paddle built-in, but an extra paddle in bed might be useful if you have a twisted mind Paddle fight! Quote Link to comment Share on other sites More sharing options...
Junie Posted November 12, 2001 Author Share Posted November 12, 2001 quote: Originally posted by Nukey Shay: You could use a serial-port extension cable as an extension Which are you referring to-- The cable is already to go? Or simply use the cable for the wire when making a extension? The only type of cable I have found ready to go, only connects a few of the pins, not all 9 of them. For example a mouse uses only 5. Junie Quote Link to comment Share on other sites More sharing options...
jsoper Posted November 12, 2001 Share Posted November 12, 2001 I bought a DIN 9 extension cable at an electronic supply store and it was fully wired out. Genesis extension cables will be too, I've picked a few up in Funcoland for a buck or two, not very rare John Quote Link to comment Share on other sites More sharing options...
