PAH Posted November 1, 2004 Share Posted November 1, 2004 I'm just getting started with 2600 programming, and figured hacking a game or two to use the trackball controller would be a good start. I see that Thomas Jentzsch has already hacked Missile Command for the trackball, so if nobody else is working on Millipede and/or Centipede, I figure I'll tackle them. That said, I realize there are two models of trackballs out there, the cx-80 and cx-22. What are the differences between these? There is no number on my trackball, so I'm not sure which one I have. Also, can anyone point me to some info on how the trackballs behave from a software point of view - i.e. which bits do what when you move the ball this way or that way? Thanks, Pete Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted November 1, 2004 Share Posted November 1, 2004 Well, implementing the Trakball into other games is not as easy as it might look like. Since the Trakball has a very high resolution, you have to check the values very frequently. The only way here is doing this inside the display kernel. Since this requires some extra time, only games with very simple kernels (with free CPU time) will work here. And since Centipede/Millipede have a quite complicated kernel, I am afraid your idea won't work. Quote Link to comment Share on other sites More sharing options...
Zach Posted November 2, 2004 Share Posted November 2, 2004 You know, I've been wondering if Centipede/Millipede TB could be pulled off with flickering? That is, read the trackball in one frame and draw the kernel in the next. Quote Link to comment Share on other sites More sharing options...
Zach Posted November 2, 2004 Share Posted November 2, 2004 By the way: Also, can anyone point me to some info on how the trackballs behave from a software point of view - i.e. which bits do what when you move the ball this way or that way? If I were you, I'd search the Stella list, and also disassemble Thomas' Missile Command TB and compare it to a disassembly of the original. Here's a good link to start with: http://www.biglist.com/lists/stella/archiv...0/msg00472.html By the way #2: Even if Centipede/Millipede won't work. I always thought Othello TB would be fun. It may even be feasible. Quote Link to comment Share on other sites More sharing options...
Zach Posted November 2, 2004 Share Posted November 2, 2004 OK. I answered my own question about Centipede with flickering by reading the link above. You need about 20 reads per frame to get a goodcontrol over the cursor. Doing it only once per frame would only result in jerky movement, as you would never be able to read the next value of the code sequence. So when Thomas said "very frequently", he meant more than once per two frames. Quote Link to comment Share on other sites More sharing options...
PAH Posted November 3, 2004 Author Share Posted November 3, 2004 Thanks for the feedback. I guess I should have thought of the resolution issue and clearly centipede/millipede have busy kernels. Quote Link to comment Share on other sites More sharing options...
tony clifton Posted November 4, 2004 Share Posted November 4, 2004 you all sound like a bunch of hacks so you probably all belong to hang out here. I will not though because you smell like a bunch a wrestlers Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted November 4, 2004 Share Posted November 4, 2004 And I smell a troll. Quote Link to comment Share on other sites More sharing options...
uosipa llamxew Posted November 5, 2004 Share Posted November 5, 2004 And I smell a troll. Yup... four posts, and each are equally ridiculous. For a long time I actually thought that the "ignore" feature was an unnecessary feature in this forum. In the last month I've added three members to my list. :-P Quote Link to comment Share on other sites More sharing options...
tony clifton Posted November 5, 2004 Share Posted November 5, 2004 I am tony clifton! show some respect you dirtballs or go play your new game man going down on wrester Quote Link to comment Share on other sites More sharing options...
Inky Posted November 7, 2004 Share Posted November 7, 2004 I am tony clifton! show some respect you dirtballs or go play your new game man going down on wrester Forget about checking out for the first sign of intelligence from this troll. Quote Link to comment Share on other sites More sharing options...
