64squares Posted November 5, 2004 Share Posted November 5, 2004 On the CX40 Atari joystick (just the regular Atari joystick), what is the best way to get that little circular black plastic ring that holds the rubber boot down out without breaking the tabs? There must be some trick to it because the thing sure is fragile. Thanks in advance for your response! Quote Link to comment Share on other sites More sharing options...
Dr. Van Thorp Posted November 5, 2004 Share Posted November 5, 2004 Maybe if you remove the screws and take the base apart, you can get to the tabs from underneith. Quote Link to comment Share on other sites More sharing options...
64squares Posted November 5, 2004 Author Share Posted November 5, 2004 Thanks, I tried that. I tried using a flat blade screwdriver gently on the tabs from underneath, but still ended up breaking the ring. Quote Link to comment Share on other sites More sharing options...
vintagegamer89 Posted November 5, 2004 Share Posted November 5, 2004 Yeah, those things are a female dog to get out. Quote Link to comment Share on other sites More sharing options...
