mvigor Posted November 19, 2004 Share Posted November 19, 2004 So I used BBEdit to wrap the .CCU file every 64 characters and displayed it in a monospace font and it's pretty readable. Am I going to run into any trouble directly editing it this way and then dropping it back onto one continuous line when I'm done? I can see that I'll have to manually decide what bankswitching method to use and all that, but it should work right? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 19, 2004 Share Posted November 19, 2004 It seems like you're just making it harder on yourself. It's much easier to edit the menu.txt file and run it through the menu generator program to create the MENU.CC2 file. Mitch Quote Link to comment Share on other sites More sharing options...
bjk7382 Posted November 19, 2004 Share Posted November 19, 2004 Yes, you are better off just working with the menu.txt file Then after you get that how you want it, then run it thru the menu generator program, and then your pretty much done. If you want to PM me I can guide you thru how to do it for the first time, but after you learn how, you won't believe how easy it really is. Quote Link to comment Share on other sites More sharing options...
mvigor Posted November 22, 2004 Author Share Posted November 22, 2004 The main reason I ask is because I keep my ROMS on my mac and my only PC is a Connectix Virtual PC program. Windows 95 boots reasonably fast, but running Windows 2000 is painfully slow. Every time I wanted to change the CC2 menu I'd have to boot the virtual pc, copy the memory card contents over to it and then get started editing, blah blah blah, transfer it all back over to the mac side for USB support and then fill the memory card again. I'm actually quite skilled at using BBEdit text editor to quickly convert any bunch of text into any other format, layout, whatever. I'm not convinced that using the generator program would be my fastest option. I'll just have to give it a try and see if it works. Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted December 1, 2004 Share Posted December 1, 2004 The main reason I ask is because I keep my ROMS on my mac and my only PC is a Connectix Virtual PC program. Windows 95 boots reasonably fast, but running Windows 2000 is painfully slow. Uhhhh... you're using VPC just so you can run the menu utilities? Geez. Here are binaries right off of my powerbook. cc2menuconv MENU.TXT MENU.CC2 cc2menugen (run in same directory as CC2ROMDB.TXT and cart binaries) cc2serial version 1.2 - 2004-08-24 Usage: cc2serial [options] [input file] Options: -r baud baud rate -b name bank switch filename (default 4K) -s name startup filename (default 78BIOS) Valid bank switch names: 2K 3F 4K 7800_16K 7800_32K 7800_48K 7800_4K 7800_8K 78POKEY 78SCR8SM 78SC_BIG 78SC_LOW 78SC_POK 78SC_R16 78SC_R8K 78SC_SM ABS78 ACT78 CV E0 E7 F4 F4SC F6 F6SC F8 F8R F8SC FA FANR FE HSC_16K HSC_32K HSC_48K MEGABOY SC UA 7800_ROF Valid startup names: 26QUICK 78BIOS 78QUICK F6BANK0 F8BANK1 HSC HSCQUICK SC (example: cc2serial -r 115200 -b 7800_16K -s 78QUICK <tubes.bin >/dev/cu.USA19*.1 cc2utils.zip Quote Link to comment Share on other sites More sharing options...
mvigor Posted December 2, 2004 Author Share Posted December 2, 2004 You converted the menu generator to run in Unix? Awesome! I'm going to get this running today! Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted December 6, 2004 Share Posted December 6, 2004 You converted the menu generator to run in Unix? Awesome! I'm going to get this running today! Uh, no, it was in the source package somewhere (I think it's makemenu.c) and I just compiled it and renamed the binary to something easier to remember. I did write cc2serial, however. Quote Link to comment Share on other sites More sharing options...
