ATARIeric Posted December 13, 2004 Share Posted December 13, 2004 is a standard RS-232 cable pin out the same as on the A8 controller ports ? i do have a gender changer for my cable. thanx, Eric Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted December 14, 2004 Share Posted December 14, 2004 You mean the joystick ports? No! Quote Link to comment Share on other sites More sharing options...
ATARIeric Posted December 14, 2004 Author Share Posted December 14, 2004 thankyou, i was curious and i didnt want to rip out of package to test i do have the joystick extension cables Quote Link to comment Share on other sites More sharing options...
dinosaur Posted December 14, 2004 Share Posted December 14, 2004 The only way to get RS-232 I/O from an Atari 8 bit is with the use of additional hardware.The most common are: Atari 850 ICD P:R: Connection ICD MIO CSS Black Box SWP ATR-8000 These use the SIO bus or the parallel bus interface (PBI) You can interface RS-232 I/O from the joystick ports,but you must build a device called an RVerter.This was homemade,never offered commercially. I can't find the URL for it,but a search of XLSearch or Google should find it.If you can't find it,PM me and I'll send you the text file on how to build one+ the R: Handler file. Quote Link to comment Share on other sites More sharing options...
dinosaur Posted December 14, 2004 Share Posted December 14, 2004 Pardon my mistake,the RVerter is an SIO device also. My error. Quote Link to comment Share on other sites More sharing options...
dinosaur Posted December 14, 2004 Share Posted December 14, 2004 Here is the RVerter text file and R:Handler: rverter.zip Quote Link to comment Share on other sites More sharing options...
cas Posted December 14, 2004 Share Posted December 14, 2004 Hi, Roland Buehler from ABBUC Regional Stuttgart published an RS-232 for the Cartridge Port. See (german) documentation at http://www.strotmann.de/twiki/bin/view/APG...ArgsSeriellCart ( we might find someone to translate this if anyone is interested). I also have (somewhere) a commercial Terminalsoftware for the Atari 800 with an RS-232 cable for the Joystick port. So it should be possible to do simple serial communication over the Joystick port(s). Best regards Carsten Strotmann Quote Link to comment Share on other sites More sharing options...
dinosaur Posted December 14, 2004 Share Posted December 14, 2004 The short-lived Canadian magazine , ROM, described a simple joystick interface,using a diode. This was used to transfer files from the 8bit to the ST. I couldn't get it to work. Quote Link to comment Share on other sites More sharing options...
