Cousin Vinnie Posted December 23, 2004 Share Posted December 23, 2004 In this week's game, you pick your better game and got at it, seeing how much you can score. These two shooters' difficulty curves and high scores in the HSC are very close, so the competiton between the two games is fair... It's just a matter of taste. Good luck, here are a few ground rules: ***Game ends Wed night at midnight ***Both games should be played on med difficulty ***Report your score and also which game you achieved it on. Here are the results of Week 25 Yep, whenever a game isn't popular, odds are I'll win it. Yipee! Cousin Vinnie 31,560 Classic Pac 29,800 Trip Cannon 16,510 Goochman 470 Overall points: 1. Jedi Jeff 105 2. Cousin Vinnie 84 3. Trip Cannon 82 4. Rockman X 40 5. RJ 37 6. Goochman 30 7. BJK 24 8. Classic Pac 21 9. NE146 13 10. Shannon 9 11. Devo 5 11. Fire Tiger 5 13. Atari Wizard 0 13. CShell 0 13. Apolloboy 0 Check out the 7800 HSC page for details Enjoy! Cousin Vinnie Quote Link to comment Share on other sites More sharing options...
Classic Pac Posted December 23, 2004 Share Posted December 23, 2004 and I have a scoring tip for Desert Falcon When you face the boss at the end of the level position your man so it fire just below the lower lip of the boss. Believe it or not you will be able to kill anything it throws at you...execpt for ground based eniemes those you still have to watch out for. All I can suggest then is move to one side and then move back and keep on firing as long as you like. Quote Link to comment Share on other sites More sharing options...
Classic Pac Posted December 26, 2004 Share Posted December 26, 2004 I should of said the above tip only works with some level bosses. I also have another tip, besides my new avatar (aren't AIM buddy icons cool) Desert Falcon as I have recently found out again can only be played 2 ways, first is for levels, second is for points. I say this because after playing this game again (in some time, I may add) the longer you take to get to the Sphinx the harder it gets just plain getting there. If you ever played Elevator Action you know what I am talking about Quote Link to comment Share on other sites More sharing options...
Classic Pac Posted December 27, 2004 Share Posted December 27, 2004 109,826 for Desert Falcon Quote Link to comment Share on other sites More sharing options...
FireTiger Posted December 27, 2004 Share Posted December 27, 2004 What difficulty level? Tips: DF -check out my codes http://www.atariage.com/forums/viewtopic.p...t=desert+falcon (quoted below) Hello, realizing there are the following possible Heiro's and order matters with duplicates allowed... what are you favorite 'special powers/inhibitors', what code, what level, and at what setting? I wonder if there is a correlation between the Heiros and the Power, becides that triplets are nearly always non-points powers. I am really looking for codes that do not give points, perhaps another list. I have not beaten the game yet. -lvl 5 eats me up on novice with the green/yellow tracking wait till you move Scarabs and Vultures. Description, lvl #, land color, water color lvl 1 - Tan and Blue lvl 2 - Green and 'Purple' lvl 3 -Sliver and Green lvl 4 -Black and Magenta lvl 5 - Dark Green and Dark Blue lvl 6 - Black and purple, light blue minis and gold buildings Heiro's A = Ankh B = Bird U = Bowl ("U" looks like a bowl shape) C = Cane E = Eye F = Feather M = Man S = Sun over Water Special ability list (incomplete) Inhibitors (activate Automaticly) PW = Polywater (No Swimming) S = Shackle (No Walking) BW = Broken Wing (No Fying) SD = Slow Down (actually you can 'hover', swim and walk faster than fly.) Neutral R = Roulette (two 'random' Heiros, usually men and/or bowls) SU = Speed Up (watch out! don't crash) Powers A = Air Bomb O = Omnicide I = Invincible (except for crashing) D = Decoy HS = Hold Sphinx (Howling Sphinx) KU = Kill Uwes KP = Kill Pots (Fire pots) KS = Kill Sphinx (must be on screen!-carry it around to hard lvls) KM = Kill Minis (mini Sphinx) P = Points (activates Automaticly) W = Warp (to Howling Sphinx) EL = Extra Life (activates Automaticly) QS = Quick Shots EB = Extra Bonus (activates Automaticly) Examples: EL, BBB, lvl 3-?, Novice EB, FFM, lvl 1, Novice EB, BBB, lvl 3-?, Novice QS, FCB, lvl 3, Novice QS, FMB, lvl 3-?, Novice QS, SMB, lvl 3-?, Novice QS, BBB, lvl 1-2, Novice QS, ASU, lvl 2, Novice QS, ABM, lvl 2, Novice I, MME, lvl 1, Novice W, BBE, lvl 3-?, Novice W, MMB, lvl 1-2, Novice W, CUU, lvl 1-2, Novice D, UEU, lvl 1-2, Novice D, BUE, lvl 1-2, Novice SD, BAE, lvl 3-?, Novice SD, CBF, lvl 1-2, Novice SU, FSE, lvl 6, Novice SU, ACF, lvl 3, Novice SU, FFF, lvl 2-3, Novice AB, BAS, lvl 5 (+,- ?), Novice AB, UEE, lvl 1-2, Novice KS, SFC, lvl 1, Novice KM, SUE, lvl 5 (+,- ?), Novice KU, AMC, lvl 2, Novice BW, XXX, lvl 5 (+,- ?), Novice (dropped code) Standard Game... just for the peps who are going to do the DF HSC CODES: ALL for STANDARD game I = EFA , lvl 1 R = UAA, lvl 1 QS= EES, lvl 1 P =MCU, lvl 1 O = CAF, lvl 1 HS = MBB, lvl 1 R = CEC, lvl 2 HS = CEM, lvl 2 HS = FBA, lvl 2 D = EAC, lvl 2 PW =MUB, lvl 3 Quote Link to comment Share on other sites More sharing options...
FireTiger Posted December 27, 2004 Share Posted December 27, 2004 97,347 -mer stupid obelisk! Hints DF: Three birds in level 3 or up is Extra life Killing things for some reason increases the base value of a treasure, picking up the few treasures before the Howling Sphinx for some reason multiplies the treasure value. Know how many of each treasure you have collected, its in to bottom middle, notice that after the Howling Sphinx the ratio of the treasure that you have collected the most for to the other treasures is low... Never play two player, as the second player with someone that can get to level 4-5 ...you start off with lvl one speed and level 4-5 baddies! (someone needs to fix this in a hack!) Minis are worth 1000 pts each...kill 10 for a quick extra life You can only carry the spirit of so many treasure hunting falcons at once (lives) The max is 7, not counting the one you use now. (someone needs to fix this in a hack!) Quote Link to comment Share on other sites More sharing options...
RJ Posted December 28, 2004 Share Posted December 28, 2004 Can we just use the scores we got in previous HSCs? Quote Link to comment Share on other sites More sharing options...
FireTiger Posted December 28, 2004 Share Posted December 28, 2004 IMHO that's cheating to use previous scores, once I got a tone of points on midnight magic (2600 HSC) but didn't post em... Quote Link to comment Share on other sites More sharing options...
FireTiger Posted December 28, 2004 Share Posted December 28, 2004 xevious- 12,785 -Ack Quote Link to comment Share on other sites More sharing options...
Trip_Cannon Posted December 28, 2004 Share Posted December 28, 2004 Xevious - 114,640 Quote Link to comment Share on other sites More sharing options...
jedijeff Posted December 30, 2004 Share Posted December 30, 2004 I played Xevious and got 197360. Jeff Quote Link to comment Share on other sites More sharing options...
