vdub_bobby Posted February 16, 2005 Share Posted February 16, 2005 So, I'm trying my first stab at bank-switching...and I've got this code in bank 1: org $1FF5 rorg $FFF5 SwitchToBank2Subroutine lda $1FF9 ;switch to Bank 2 rts ;return from subroutine And this code in bank 2: org $2FF5 rorg $FFF5 SwitchToBank1Subroutine lda $1FF8 ;switch back to bank 1 jmp Bank2SubroutineSelect With the idea that, while in bank 1 I can 'jsr SwitchToBank2Subroutine' and it will switch to bank 2 and, once in bank 2, I do whatever I want to do and, then, to switch back I 'jmp SwitchToBank1Subroutine' which will switch me back, grab the rts and go back to the original subr call. This works in PCAE. But in z26 it is grabbing the rts before it switches banks but executing it in the second bank. Here's the relevant part of the z26 log file: ( 1 4 30 22) ( 69 39 8 2 2) nvbdIZc 00 00 00 ff f03f: 29 3f and #3f ( 1 4 32 28) ( 69 39 8 2 2) nvbdIZc 00 00 00 ff f041: f0 02 beq f045 ( 1 4 35 37) ( 69 39 8 2 2) nvbdIZc 00 00 00 ff f045: a2 00 ldx #00 ( 1 4 37 43) ( 69 39 8 2 2) nvbdIZc 00 00 00 ff f047: 20 f5 ff jsr fff5 ( 1 4 43 61) ( 69 39 8 2 2) nvbdIZc 00 00 00 fd fff5: ad f9 1f lda 1ff9 <--- bank switch here ( 1 4 47 73) ( 69 39 8 2 2) nvbdIzc 03 00 00 fd fff8: 60 rts <--- this is in bank 1?! ( 1 4 53 91) ( 69 39 8 2 2) nvbdIzc 03 00 00 ff f04a: 85 81 sta 81 <--this is in bank 2!? ( 1 4 56 100) ( 69 39 8 2 2) nvbdIzc 03 00 00 ff f04c: 4c 5e f0 jmp f05e ( 1 4 59 109) ( 69 39 8 2 2) nvbdIzc 03 00 00 ff f05e: a4 f6 ldy f6 ( 1 4 62 118) ( 69 39 8 2 2) nvbdIZc 03 00 00 ff f060: e6 f6 inc f6 What am I doing wrong here? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted February 16, 2005 Share Posted February 16, 2005 Nothing wrong that I can see...but some addresses seem to execute slower than others. Have a look here: http://www.atariage.com/forums/viewtopic.php?t=58667 Very similar to the problem you are describing. BTW You can use STA's instead of LDA's to trigger the bankswitch (so you can save A from being overwritten). The bankswitch will happen no matter how those addresses are accessed Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted February 16, 2005 Author Share Posted February 16, 2005 Nothing wrong that I can see...but some addresses seem to execute slower than others. Have a look here:http://www.atariage.com/forums/viewtopic.php?t=58667 Very similar to the problem you are describing. BTW You can use STA's instead of LDA's to trigger the bankswitch (so you can save A from being overwritten). The bankswitch will happen no matter how those addresses are accessed Thanks; I found that thread immediately after posting this - I've tried a few things, and nothing's helped It seems like z26 is waiting waiting waiting to switch banks until...something? I added a nop after the 'lda $1FF9' and it then grabbed the nop AND the rts before switching banks. I added another nop and it grabbed both nops AND the rts and then switched banks. I tried three nops, same thing. I moved the 'rts' statement in front of the 'lda $1FF9' statement like this: Bank 1: org $3FF0 rorg $FFF0 nop nop nop rts org $3FF5 rorg $FFF5 SwitchToBank2Subroutine sta $1FF9 ;switch to Bank 2 nop nop nop nop org $3FFC rorg $FFFC .word StartBank1 ;$F003 .word StartBank1 ;$F003 And in Bank 2: org $4FF0 rorg $FFF0 SwitchToBank1Subroutine sta $1FF8 nop nop nop nop nop jmp Bank2SubroutineSelect ;this is at addy $4FF8/$FFF8 nop org $4FFC rorg $FFFC .word StartBank2 ;$F000 .word StartBank2 ;$F000 And got this truly weird log file from z26: ...[snip]...ff f045: a2 00 ldx #00 ...[snip]...ff f047: 20 f5 ff jsr fff5 <--bank 1 ...[snip]...fd fff5: 8d f9 1f sta 1ff9 <--switch to bank 2? ...[snip]...fd fff8: ea nop <--bank 1/2? ...[snip]...fd fff9: 03 f0 slo (f0,x) = CXM0P <--what the...? F003 is the start/brk vector (in bank1), but it isn't at FFF9 ...[snip]...fd fffb: ea nop <--bank 1 or 2? ...[snip]...fd fffc: 00 brk <--huh? I guess we are in bank 2 now; this is the LSB of the brk vector in bank 2. ??? So that takes us to ...[snip]...fa f000: ad f8 1f lda 1ff8 <--Where a bank switch to bank 1 is performed, no problem (this time), to ...[snip]...fa f003: 78 sei <--the init code This doesn't even make sense to me...I'm running z26 v. 2.13. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted February 16, 2005 Share Posted February 16, 2005 Aaaa...I missed something easy! Your instructions exist past $xFF7! org $1FF5 rorg $FFF5 SwitchToBank2Subroutine ($FFF5-7) lda $1FF9 ;switch to Bank 2 ($FFF8) rts ;return from subroutine And this code in bank 2: org $2FF5 rorg $FFF5 SwitchToBank1Subroutine ($FFF5-7) lda $1FF8 ;switch back to bank 1 ($FFF8-B) jmp Bank2SubroutineSelect The program counter itself was probably causing the bankswitch. Move them back a little: org $1FF2 rorg $FFF2 SwitchToBank2Subroutine ($FFF2-4) lda $1FF9 ;switch to Bank 2 ($FFF5) rts ;return from subroutine ($FFF6) NOP;unused ($FFF7) NOP;unused And this code in bank 2: org $2FF2 rorg $FFF2 SwitchToBank1Subroutine ($FFF2-4) lda $1FF8 ;switch back to bank 1 ($FFF5-7) jmp Bank2SubroutineSelect Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted February 16, 2005 Author Share Posted February 16, 2005 Aaaa...I missed something easy!Your instructions exist past $xFF7! !!! That worked; Thanks a million! So what, exactly, should I be avoiding here? Any code past $xFF7? Can I put data there? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted February 16, 2005 Share Posted February 16, 2005 Nope...you can't use them at all in either bank. The moment that those addresses are accessed at all it would cause a bankswitch. the 2 NOP instructions above could be replaced with a 2-byte data table tho...if you have one. BTW you also need to make sure that the cart can boot from either bank. ;boot code (bank1) START1: STA $1FF9 NOP NOP NOP ;boot code (bank2) START2: NOP NOP NOP JMP START;jump to init routine That will insure that the cart can boot from either bank (because on power-up, this flip status will be unknown). The init routine exists in bank2 in this example...switch them around if your init routine is in bank1. The vector at $FFFC would be START1/START2 instead of START. Quote Link to comment Share on other sites More sharing options...
+batari Posted February 16, 2005 Share Posted February 16, 2005 So what, exactly, should I be avoiding here? Any code past $xFF7? Can I put data there? The 6507 does a dummy fetch of PC+1 when executing an RTS, so you can't put an RTS at xFF7 either as it would switch banks. You'd need to bump it up to xFF6. I've found that some emulators don't emulate the dummy fetch, so this might lead to strange bugs that don't turn up until you try to run on a console. I think you're OK with data at xFF7. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted February 16, 2005 Share Posted February 16, 2005 I've found that some emulators don't emulate the dummy fetch, so this might lead to strange bugs that don't turn up until you try to run on a console. Usually PCAE only emulates correct code correctly, z26 is much better for developing as it also emulates a lot of incorrect code incorrectly. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted February 16, 2005 Share Posted February 16, 2005 ^ incorrect code correctly So what would not emulate correctly coded games incorrectly? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted February 16, 2005 Share Posted February 16, 2005 So what would not emulate correctly coded games incorrectly? z26 and Stella more often than PCAE. Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted February 16, 2005 Author Share Posted February 16, 2005 I've found that some emulators don't emulate the dummy fetch, so this might lead to strange bugs that don't turn up until you try to run on a console. Usually PCAE only emulates correct code correctly, z26 is much better for developing as it also emulates a lot of incorrect code incorrectly. Yeah, I have noticed that PCAE isn't as accurate as z26 in some weird cases - but that debugging tool is sure handy Oh, and thanks for all the help with the bank switching. Quote Link to comment Share on other sites More sharing options...
