Feralstorm Posted February 23, 2005 Share Posted February 23, 2005 In the words of Hawkeye Pierce, "It's not much, but it's really nothing." I was mostly trying to find out if I could hack game graphics with just my Amiga and a hex editor. Turns out I can, so I may try doing some more ambitious stuff in the future. Starting Point: Rob Kudla's arcade hack of Space Invaders What was done: tweaked the graphics for the middle two rows of invaders, changed the UFO graphics, and changed the base explosion animation to be more arcade-like. I'm no threat to the pro hackers out there, but at least I can play a little. Apologies to Mr. Kudla for re-tweaking his work. spcinvdr.zip Quote Link to comment Share on other sites More sharing options...
neotokeo2001 Posted February 24, 2005 Share Posted February 24, 2005 Starting Point: Rob Kudla's arcade hack of Space Invaders What was done: tweaked the graphics for the middle two rows of invaders, changed the UFO graphics, and changed the base explosion animation to be more arcade-like. Space Invaders is a perfect game to choose for your first hack. My first attempt at hacking was also Space Invaders. Try to do some wholesale changes to the graphics with a different theme. Quote Link to comment Share on other sites More sharing options...
Feralstorm Posted February 24, 2005 Author Share Posted February 24, 2005 Apparently I wasn't satisfied, so I did a little more work to the Invaders hack, this time making the middle row aliens one pixel 'meatier'. Also here is another 'mildly improved' graphic hack of Donkey Kong, which needs more than I can figure out right now to make it look right (mostly modifying the sprite coloration). I tinkered with almost all sprites on this one. I tried hacking Dig Dug, and discovered that if I changed one byte pretty much anywhere, the game would turn to trash. Don't really know why (bankswitching? the other games I did were 4K). Would explain why I don't see much in the way of Dig Dug hacks though, spcinvdr.bin dkews.bin Quote Link to comment Share on other sites More sharing options...
StanJr Posted February 25, 2005 Share Posted February 25, 2005 Since you are just getting your feet wet and discovering the amazing world of Hacking, I'll hold off on adding any of these to the Hacks Database for now. If you have a particular hack you want to make sure gets into the database, just send me a FINAL BIN, and I'll see that it gets up. Quote Link to comment Share on other sites More sharing options...
Feralstorm Posted February 25, 2005 Author Share Posted February 25, 2005 Kewl, thanks. The Space Invaders re-hack is pretty much as done as it's gonna be (most of the hard work was already done for me). I'll have to see if someone can point out to me how to modify sprite colors on the DK hack (or just tell me which bytes to hit, since I'm hex-editing and not disassembling) Other than that, I'll have to see if there's anything I can do that's a bit more creative than making games more arcade-like when they were arleady fairly close to start with. Quote Link to comment Share on other sites More sharing options...
Zach Posted February 26, 2005 Share Posted February 26, 2005 I tried hacking Dig Dug, and discovered that if I changed one byte pretty much anywhere, the game would turn to trash. Don't really know why (bankswitching? the other games I did were 4K). You're right that the problem is bankswitching. If you are hacking Dig Dug or any other superchip game, you'll need to run the emulator in superchip mode. The following command line works for Z26: z26 -g6 dighack.bin Good luck with your hacking. Quote Link to comment Share on other sites More sharing options...
