jammajup Posted March 12, 2005 Share Posted March 12, 2005 Hi all! I have an F1 Dream on the test rig at the moment with a `foreground` sprite problem.The sprites appear to be drawn in horizontal strips/segments but every other section is drawn around two inches to the left of the true position like so.. I am currently checking a few 74 series ic`s near the many MCM2018N45 slimline rams, has anybody had something simular with these Capcom boards?,i do not look forward to changing my first slimline ram. Quote Link to comment Share on other sites More sharing options...
Stingray Posted March 14, 2005 Share Posted March 14, 2005 A good first step would be removing any socketed chips one at a time, clean the pins and resocket them. I don't have any experience with that board though, this is just generic advice. -S Quote Link to comment Share on other sites More sharing options...
jammajup Posted March 15, 2005 Author Share Posted March 15, 2005 Hi! S Yes that is always my first move,cleaning the ic legs with a pencil eraser before re-seating them (also a good method for cleaning the edge connector). Tom i will replace a 74LS374 (octal Flip-flop),it is receiving clock signals and the chip is enabled but the output is not switching in response.Failing that,if i can see nothing else suspicious i may have to change some rams. Quote Link to comment Share on other sites More sharing options...
Cassidy Nolen Posted March 15, 2005 Share Posted March 15, 2005 I'm thinking RAM as well on that one. If you have an eprom burner, might be worht pulling the graphic roms and seeing if they are any good. Bit rot maybe? Seems more likely a RAM thing though. Cassidy Quote Link to comment Share on other sites More sharing options...
sebastius Posted March 21, 2005 Share Posted March 21, 2005 Looks familiar, i've got a similar problem with a capcom game I've got (Carrier Airwing). The problem was that I couldn't reach the chips on the bottom board with my logic analyser, so I replaced the bottom board and the game worked fine again. Your problem is not a Bit-Rot one, maybe RAM, but I suspect RAM adress decoding or the buffer from the ram to the video portion which has an enable line. Maybe the buffer is faulty or the circuit that drives it. Good luck! Quote Link to comment Share on other sites More sharing options...
