Haydn Jones Posted March 25, 2005 Share Posted March 25, 2005 I want to try and hack a rom, but due to a few dead links i cant find a dissasembler or its source code. Any tips? Haydn Quote Link to comment Share on other sites More sharing options...
DEBRO Posted March 25, 2005 Share Posted March 25, 2005 I want to try and hack a rom, but due to a few dead links i cant find a dissasembler I assume you mean the 2600. If so then Distella is what you're looking for. The new version also works for 7800 games. If you mean the A8/5200 then Dis6502 is what you need. or its source code. Any tips? What game? It may have been fully or partially disassembled. Quote Link to comment Share on other sites More sharing options...
Haydn Jones Posted March 25, 2005 Author Share Posted March 25, 2005 night driver haydn Quote Link to comment Share on other sites More sharing options...
Haydn Jones Posted March 25, 2005 Author Share Posted March 25, 2005 2600 sorry haydn Quote Link to comment Share on other sites More sharing options...
DEBRO Posted March 25, 2005 Share Posted March 25, 2005 night driver haydn Here's a partial disassembly I started a while back. Be warned...I haven't touched this in a number of months. night_driver.zip Quote Link to comment Share on other sites More sharing options...
Haydn Jones Posted March 25, 2005 Author Share Posted March 25, 2005 cool, thankyou very much! Haydn Quote Link to comment Share on other sites More sharing options...
MayDay Posted March 26, 2005 Share Posted March 26, 2005 I've downloaded Distella and it works fine, my problem is just user error. I've put processor 6502 and include vcs (and actually also tried putting the variables directly into the code). Any idea why I can't recompile it correctly? (it does compile, but only displays black in z26). Also, does anyone have the binary (or better yet the .asm) for Ice Hockey? I noticed none (or at least very few) of the Activision games have ROMs, is there a reason for this? C&D perhaps? I know they are still an active company and thought this may have something to do with it. Thanks, J.D. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 26, 2005 Share Posted March 26, 2005 There's a little trick that I use when disassembling games to try to find anything that was done incorrectly...just after disassembling a binary for a game with Distella, I immediately take that disassembly (without making any changes to it), and assemble it with Dasm. Then, I do a file compare under Dos to see if anything differs. For example: distella -pafs pacman.bin > pacman.asm dasm pacman.asm -f3 -opac.bin fc /b pacman.bin pac.bin > changes.txt Dos will report anything that is different between the 2 binaries, and put all of them in the file named changes.txt The memory locations of all of the mistakes will be listed to track down the cause better. Can you post your disassembly? It should be easy enough to figure out what went wrong with it. Quote Link to comment Share on other sites More sharing options...
MayDay Posted March 26, 2005 Share Posted March 26, 2005 That's a neat little trick, thanks. I also saw in the Distella help files where you can "config" the output to include things such as ROM, code, graphics, etc. so they are displayed in comments. Know the commands to make any/all of these happen? As for the disassembly, I don't have WinZip and already have cluttered the forum in the newbie section. If I have further problems, I'll look it up so I can post stuff for you. -J.D. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 26, 2005 Share Posted March 26, 2005 It's not a command...but an extra switch thrown into the distella command line (-cfilename = disassemble using a config file). You need to actually SUPPLY the config file tho. What those are is just a text file that holds the addresses that Distella should interpret a certian way...code, data, or gfx. The way that you create them is by letting Distella run an automatic one, and then examine it for any areas that were misinterpreted. Open up a config file for an example. Ice Hockey disassembly: icehocky.zip Quote Link to comment Share on other sites More sharing options...
MayDay Posted March 26, 2005 Share Posted March 26, 2005 I've tried it on a few different games including Bowling, Battlezone, and Real Sports Volleyball (all of which original ROMs work fine). Volleyball and Battlezone won't recompile at all. For bowling, the text file ends up showing: Comparing files Bowling.bin and SOURCE3.BIN FC: Bowling.bin longer than SOURCE3.BIN Interestingly, the newly created source3.bin shows at 0K, and the original is 2K. When I try to run source3.bin through z26 I get what I like to call the "Atari musical bitch-slap scale". Basically the blue bars go to the middle, the scale is played, and z26 exits. If I can't figure it out that's okay, I'm trying to create a game, not hack one anyway. I just thought it would be nice to see some (working) code to play around with. Thanks for the help- Nukey seems to respond to newbies more than anyone else here, although vdub_bobby, Thomas Jentschz (spelling?) and several others have already helped me numerous times too. I think it's really cool you guys take the time to help us out. Maybe someday I'll be able to repay your patience with something cool! -JD Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 26, 2005 Share Posted March 26, 2005 Something is causing it to crash out when disassembling...that would be my guess. Battlezone is an 8k game, so you can't disassemble it as-is (you would need to split the binary file into 2 halves first). That would explain that one, but I dunno about RS Volleyball (4k) and Bowling (2k). What is the EXACT thing that you are typing? Can you post your disassembly of either of those 2 games? Bowling should go something like: distella -pafs bowling.bin > bowling.asm Quote Link to comment Share on other sites More sharing options...
MayDay Posted March 26, 2005 Share Posted March 26, 2005 i was typing distella -a bowling.bin > bowling.s instead of what you had. When I switched the -a to -pafs and the .s to .asm it seems to work fine for Vball and Bowling. I don't think the .s/.asm should make much diff, but what does the -pafs vs. -a do? Both games also play fine in z26, btw. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 26, 2005 Share Posted March 26, 2005 i was typing distella -a bowling.bin > bowling.s instead of what you had. When I switched the -a to -pafs and the .s to .asm it seems to work fine for Vball and Bowling. I don't think the .s/.asm should make much diff, but what does the -pafs vs. -a do? Both games also play fine in z26, btw. All that -a does is supress the letter A being used as an argument. For example, LSR $address will move the bits to the right in that memory location, while LSR with no argument will move the bits to the right in the Accumulator...one of the 65xx's registers. With the -a switch... LSR A will instead appear as... LSR Cuts down on the amount of typing The switch -p will place the text "processor 6502" into the disassembly. When assembling if you do not state the processor type, Dasm will not assemble it So it's just good practice to -at the very least- use the -p switch. You are gonna need to tell it what processor it's using anyway...might as well get it right away when disassembling. The switch -s will put the number of cycles that each instruction is using right in each line as a comment. The 2600 is extremely sensitive about how long something takes (especially in the display kernal)...so it's handy to have them listed right in each line rather than having to look them up all the time. Just as with -a...this is for your benefit. The switch -f will make Distella print out the address mode for instructions that are treating zero-page addresses (ram) as absolute addresses. With the switch... STA $00C2,X ;5 ...will appear as... STA.wx $00C2,X ;5 This is a good idea...since if you assembled the first example later, it might be interpreted as... STA $C2,X ;3 Not the same thing...it takes 1 byte less (messing up the memory locations of all tags that follow), and 2 cycles less time (the 2600 is really picky about time). As with -p, it's just a good idea to use it and save yourself all the hassles of editing later. And as mentioned before, -c lets you specify a config file that Distella should use. The filename of the config file must be entered right after the c. All of the switches can be seen by just typing distella by itself. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 26, 2005 Share Posted March 26, 2005 BTW you are correct that .s and .asm don't really matter at all. S means "source" and .asm means "assembly", to Distella and Dasm they don't mean anything. All they are interested in is if the filename exists. But since a disassembly of a game is not the same thing as a source code of a game, I usually use .asm instead (source code is THE assembly that created the binary...complete with the programmer's comments and such. Those comments are lost when the game is assembled...and lost forever if the source files no longer exist. All of the games that have been reverse-engineered too are not the source code (but due to efforts by the likes of Debro or Thomas, they can read pretty much like the original source might have...tho you still won't see the original programmer's comments/insights - those are gone forever). Use .s, .asm, whatever you want Quote Link to comment Share on other sites More sharing options...
Haydn Jones Posted March 27, 2005 Author Share Posted March 27, 2005 i couldent compile your code, but it did tell me where to look, and i have had a bit of a play with bithacker, but i would still like to do it properly some time, haydn Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 27, 2005 Share Posted March 27, 2005 ? Worked fine here. The command line I used was dasm c_flag.asm -f3 -ofilename.bin Substitute any 8-character text in place of "filename"...and don't forget to include the hyphen and letter "o" in front. Quote Link to comment Share on other sites More sharing options...
