Wiffer Posted April 26, 2005 Share Posted April 26, 2005 Is it possible to make Missile Command have a black background that stays black and doesn't rotate through different colors? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted April 27, 2005 Share Posted April 27, 2005 Is it possible to make Missile Command have a black background that stays black and doesn't rotate through different colors? 844576[/snapback] Of course Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted April 27, 2005 Share Posted April 27, 2005 Here's a quick hack. I located the various colors so you can edit them in the disassembly if you choose. I needed to alter the other game colors, because they too might cycle to a value of $00 (meaning you wouldn't be able to see the enemy missiles, for example!). Screen = black Score = blue Missile trails = white Cities = brown Ground/Bunkers = green Weapon cache/player missiles = red Explosion cloud = Yellowish green Assembly + Binary Missile_Command_black_.zip Quote Link to comment Share on other sites More sharing options...
Atariboy2600 Posted April 27, 2005 Share Posted April 27, 2005 Here's a quick hack. I located the various colors so you can edit them in the disassembly if you choose. I needed to alter the other game colors, because they too might cycle to a value of $00 (meaning you wouldn't be able to see the enemy missiles, for example!). Screen = black Score = blue Missile trails = white Cities = brown Ground/Bunkers = green Weapon cache/player missiles = red Explosion cloud = Yellowish green Assembly + Binary 844798[/snapback] Cool! Now if only you can redo that LINE target into the arcade CROSS and maybe adding a plane flying across the screen then we have a REAL arcade port of Missile Command Quote Link to comment Share on other sites More sharing options...
Atariboy2600 Posted April 27, 2005 Share Posted April 27, 2005 And just in case Quote Link to comment Share on other sites More sharing options...
Wiffer Posted April 28, 2005 Author Share Posted April 28, 2005 Nukey Shay, Thanks so very much!!! Quote Link to comment Share on other sites More sharing options...
