Luigi301 Posted May 1, 2005 Share Posted May 1, 2005 My 7800 has a problem. If I put in a 2600 cart, I get a blank screen, much like that when you have no cart plugged into a 2600. I don't know anything about repairing or diagnosing 7800s, and I have no 7800 carts to test it with. I know the 2600 cart works because it plays in my 2600. Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted May 1, 2005 Share Posted May 1, 2005 Hard to tell without trying a 7800 cart, but it could be a bad TIA. That would also cause 7800 games (except Ballblazer and Commando) to have no sound. If you don't mind opening things up, and if you're lucky enough to have a 7800 with a socketed TIA, you could try swapping with one from a known good 2600. It's the 40-pin chip in the 2600, and the similarly numbered 40-pin chip in the 7800. Quote Link to comment Share on other sites More sharing options...
Rob Mitchell Posted May 2, 2005 Share Posted May 2, 2005 if you're lucky enough to have a 7800 with a socketed TIA, you could try swapping with one from a known good 2600. It's the 40-pin chip in the 2600, and the similarly numbered 40-pin chip in the 7800.847399[/snapback] I have an extra TIA chip that I can send to you if you want to follow Bruce's suggestion. Rob Mitchell, Atlanta, GA Quote Link to comment Share on other sites More sharing options...
