bookpile Posted June 5, 2005 Share Posted June 5, 2005 Ok, here's what's on my workbench for this afternoon. 1 working 7800 2 non working 7800's that do not power on. Any ideas where to start checking with the volt meter? I'm hoping to combine the two into one good one. Thanks Quote Link to comment Share on other sites More sharing options...
Lost Monkey Posted June 5, 2005 Share Posted June 5, 2005 Ok, here's what's on my workbench for this afternoon. 1 working 7800 2 non working 7800's that do not power on. Any ideas where to start checking with the volt meter? I'm hoping to combine the two into one good one. Thanks 868266[/snapback] Go for the power switch, they can be flaky. Quote Link to comment Share on other sites More sharing options...
bookpile Posted June 5, 2005 Author Share Posted June 5, 2005 well here's what I get so far. Working console- Voltage Regultor. When turned off- both sides- 0 volts When turned on- one side- 10.6 volts- other side 5 volts Broken console- Voltage Regulator When turned off- one side has 0 volts, the other side has 3.4 volts-wtf? when turned on-nothing any ideas? Quote Link to comment Share on other sites More sharing options...
bookpile Posted June 5, 2005 Author Share Posted June 5, 2005 Update- the power switch appears to be good, as it starts off at 5 and then cycles to 0 briefly when you push the button, and the same when you turn it off Quote Link to comment Share on other sites More sharing options...
+Mitch Posted June 5, 2005 Share Posted June 5, 2005 Sounds like you might have a bad voltage regulator, try replacing it and see what happens. Mitch Quote Link to comment Share on other sites More sharing options...
