techie_alison Posted June 5, 2005 Share Posted June 5, 2005 Hello, There used to be programs supplied with ST cover disks which would switch a monitor between a 50 or 60Hz vertical refresh rate. These could be placed into an AUTO folder with there usually being 2 seperate programs for either 50 or 60Hz, or a toggle program. I'm trying to find one of these. So far I've found this program which partly does this but isn't the same as the ones on the cover disks; ftp.lip6.fr/pub/atari/Utilities/go5060hz.lzh It requires a reboot which is a bit impractical. I've searched and searched for the last few hours and aren't getting too far. Does anyone have one of these progs or a link? Thanks, Aly Quote Link to comment Share on other sites More sharing options...
techie_alison Posted June 7, 2005 Author Share Posted June 7, 2005 Hi again, Attached is a program to toggle your monitor between 50 or 60hz. Bit surprised no one uses these apps hence no reply, as if you have concerns about Elite Frontier and your ST not running fast enough, switching to 60hz increases the speed of the ST by about 20%. (less scan lines to service). 100*(50/60) = 83.33% ...(100-83.33) = 16.77% faster. Aly 50_60hz.zip Quote Link to comment Share on other sites More sharing options...
GT Turbo Posted July 11, 2005 Share Posted July 11, 2005 On C.V.S.D. Website in download party, you can download Alyzee, this little ACC allows you to select your boot frequency, the difference with other progs, that you don't need AUTO Folder, Alyzee set the frequency on the boot sector in writing a boot sector who allows display personnal message, setting frequency, setting keyboard beep, etc.. GT Turbo (C.V.S.D.) Quote Link to comment Share on other sites More sharing options...
