Questions about using the timer.
Hi, I'm seeing examples of code that use TIM64T and INTIM. I'm reading page 12 of the Stella's Programming Guide. I'm not sure I understand what it all means. It sounds like any number you move into one of the interval timers gets multiplied by that interval and starts counting down to zero. So, page 12 says if I load #100 to TIM64T, then the timer would start counting down from 6400 clocks to zero. I'm confused about what a "clock" is. Is a clock one cpu cycle? So loading #100 to TIM64T would be 6400 CPU cycles?
Another thing I am not clear on is, when the timer reaches zero, the Guide says "It holds that count for one interval". Is an interval one cpu cycle or is it 64 cpu cycles?
Jim
Great! So I'm thinking that after the last WSYNC of Vblank, if I load the correct number into TIM64T, then that will count down through all the cpu cycles of the visible 192 scanlines.
192 * 76 cycles is 14592 / 64 = 228.
or because loading TIM64 will take (I think) 5 cycles, I should load in 213.
sample code might look like this?
sta WSYNC;last wsync of the vertical blank
  ;in this example I think lda takes 2 cycles and sta takes 3 cycles
  ;so I have to subtract 5 from 76 to get 71 cycles.
  ;71 * 192 = 13632
  ;13632 / 64 = 213
   lda #213
   sta TIM64T
LOOP
 ;do some stuff
   lda INTIM
   bne LOOP
  ;we should be at the last visible scanline
OverScan
Does this look right?
jim
No, you should still load 228, by using 213 you will loose about 4 scanlines (5*64 = ~4*76). And finally do one WSYNC do hit the exact end of the last scanline.
BTW: Since the timer will go from 218 to 217 immediately, you will actually only wait for 217 timer loops.
