brainwagon Posted September 8, 2005 Share Posted September 8, 2005 I'm having some difficulty understanding horizontal positioning code, in that it doesn't behave like I expect. I began by looking at the "Revolutionary Horizontal Positioning Code", but that didn't work as expected, and so I started running some experiments on my own. This only serves to confuse me more. Here's what I think, and what I found out. I'm trying to position a player flush with the left most edge of the playfield. The playfield begins 68 TIA clocks into a scanline. So, I execute the following code sta wsync nop <repeated 10 times, for 20 cycles> sta resp0 By my count, this should execute 23 cycles or 69 clocks into the line, leaving one blank space (which presumably I could move by loading hmp0 with $10 and executing an hmove). But instead, I get the player several pixels in from the left (see the attachment). Am I fundamentally missing something about how the cycle timings work? Is there some edge condition that I'm unaware of? Until I can figure out how these simple examples work, it seems understanding the more complicated revolutionary stuff is just a pipe dream. Thanks for your patient instruction. Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted September 8, 2005 Share Posted September 8, 2005 (edited) See here: http://www.atariage.com/forums/index.php?s...ndpost&p=894475 A RESP will set the objects position to the pixel at which the write happens. But the TIA needs a couple of cycles from the pixel clock to set up the actual output. Therefore all objects will be delayed by a couple of pixels. The offset is 4 pixels for missiles and the ball, 5 pixels for single-width players, and 6 pixels for double- and quadrouple-width players. You need to take these offsets into account when calculating the position of an object. Edit: And also, any RESxx during HBlank (cycles 0 to 22) will position the object at the left-most edge* of the screen; you don't have to hit RESxx exactly at cycle 23. *Taking into account the offset listed above, of course. So hitting RESP0 between cycle 0 and 22 will position player 0 at pixel 5. Here is a sprite positioning routine that is a little easier to use than most of the others I have seen: PositionASpriteSubroutine sta HMCLR sec sta WSYNC ; begin line 1 DivideLoop sbc #15 bcs DivideLoop ;+4/5 4/ 9.../54 eor #7 ;+2 6/11.../56 asl asl asl asl ;+8 14/19.../64 sta.wx HMP0,X ;+5 19/24.../69 sta RESP0,X ;+4 23/28/33/38/43/48/53/58/63/68/73 sta WSYNC ;+3 0 begin line 2 sta HMOVE ;+3 rts ;+6 9 Set X to the index into which object you want to position (0 = player 0, 1 = player 1, 2 = missile 0, 3 = missile 1, 4 = ball) Set A to the pixel you want to position the object at. The nice thing about this routine is that, for normal-width players, setting A to zero will position the player at the left-most edge of the screen. Setting A to 159 will position the player at the right-most edge of the screen. The other nice thing about this routine is that it will always always take exactly the same number of cycles* - call this with 14 cycles left in the scanline and it will always return 99 cycles later (9 cycles into the 2nd scanline). I have used this or a variation of it in almost every 2600 binary I have written. *If you feed it a position between 0 and 159 Edited September 8, 2005 by vdub_bobby Quote Link to comment Share on other sites More sharing options...
brainwagon Posted September 8, 2005 Author Share Posted September 8, 2005 This was exactly the information I needed. I find it a bit surprising that this useful information isn't in any of the tutorial information that I've found so far. Your presentation (and routine) are probably just about the most clear that I've seen. Hmm. perhaps I should write a tutorial myself. :-) Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted September 8, 2005 Share Posted September 8, 2005 This was exactly the information I needed. I find it a bit surprising that this useful information isn't in any of the tutorial information that I've found so far. Your presentation (and routine) are probably just about the most clear that I've seen. Hmm. perhaps I should write a tutorial myself. :-) 927548[/snapback] Yeah, it can be hard to find this info. I was tearing my hair out about 6 months ago because I couldn't figure out why my double- and quad-width sprites weren't positioned where they were supposed to be. I double- and triple-checked my code for bugs, and then finally created a test binary to confirm that, yes, double-width and quad-width sprites are positioned one pixel to the right of normal-width ones. I'd never seen that information anywhere! Quote Link to comment Share on other sites More sharing options...
+xucaen Posted June 26, 2006 Share Posted June 26, 2006 I just wanted to link this post to another that explains the sta.wx HMP0,X notation. http://www.atariage.com/forums/index.php?s...st&p=905221 Quote Link to comment Share on other sites More sharing options...
Devin Posted December 21, 2007 Share Posted December 21, 2007 (edited) Here is a sprite positioning routine that is a little easier to use than most of the others I have seen: PositionASpriteSubroutine sta HMCLR sec sta WSYNC; begin line 1 DivideLoop sbc #15 ... rts ;+6 9 EDIT: Excellent! My biggest worry about my first program was positioning sprite. With just a dozen or so lines - you dispelled my problems! Thank you. Edited December 21, 2007 by Devin Quote Link to comment Share on other sites More sharing options...
