tjlazer Posted September 25, 2005 Share Posted September 25, 2005 I got this 1040STf that when loading a program from disk, screen flips on every track read. Once machine warms up it goes away. Any ideas? Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted September 26, 2005 Share Posted September 26, 2005 I got this 1040STf that when loading a program from disk, screen flips on every track read. Once machine warms up it goes away. Any ideas? 937946[/snapback] Do the time honored 4" drop onto a hard surface. If it works, then you'll need to eventually break open the case and make sure all the socketed chips are pressed in firmly. If it doesn't work, I'd suspect a weak power supply. Just some random thoughts. HTHs. :-) Quote Link to comment Share on other sites More sharing options...
TwiliteZoner Posted September 26, 2005 Share Posted September 26, 2005 (edited) I got this 1040STf that when loading a program from disk, screen flips on every track read. Once machine warms up it goes away. Any ideas? 937946[/snapback] Do the time honored 4" drop onto a hard surface. If it works, then you'll need to eventually break open the case and make sure all the socketed chips are pressed in firmly. If it doesn't work, I'd suspect a weak power supply. Just some random thoughts. HTHs. :-) 938007[/snapback] I still remember calling Atari when I got my first ST (520ST). I called because the desktop was blank and there were no disk icons. The woman on the phone said pick the computer up a couple of inches and drop it on the table and I went WHAT!?!?!?! It worked though......... Edited September 26, 2005 by TwiliteZoner Quote Link to comment Share on other sites More sharing options...
