SeaGtGruff Posted October 1, 2005 Share Posted October 1, 2005 I don't know if I'm losing my mind, or what. Last year I started working on a game (which has been shelved for now) that uses M-Network bankswitching. I was using the adev.exe (Atari Dev) program to write in assembly, compiling with DASM, and running the program with z26, all from within the adev program. I had to use the -g9 switch to tell z26 that the program should use the M-Network cart style, but it was working. This is how I set up the banks: Bank 0 = $C000 (relocated to $F000) Bank 1 = $C800 (relocated to $F000) Bank 2 = $D000 (reloacted to $F000) Bank 3 = $D800 (relocated to $F000) Bank 4 = $E000 (relocated to $F000) Bank 5 = $E800 (relocated to $F000) Bank 6 = $F000 Bank 7 = $F800 To be more specific, I hadn't learned about RORG yet, so I created the 8 banks as separately-compiled 2K binaries at $F000, but with the last 2K bank at $F800. Then I combined the binaries using INCBIN, starting at $C000. Okay, so this week I've been trying to get M-Network bankswitching to work with batari BASIC. (This post is *not* about bB, so that's why I'm posting here rather than in the bB forum.) The problem is, I can't get the 16K ROM to run correctly, unless I put bank 7 as the second 2K block, like this: Bank ? | Bank 7 | Bank ? | Bank ? | Bank ? | Bank ? | Bank ? | Bank ? In other words, the first 4K of the binary is loading at $F000 through $FFFF, and the remaining 12K apparently isn't getting loaded at all-- which I guess is right, since the other banks aren't really there until they get switched in. So now I'm totally confused, because last year, and in January/February of this year, I was putting bank 7 last and it was working. It's as if z26 was working differently then (and I also ran it on Stella, which was working the same way). Can anyone explain the order the banks should be in? If I look at BurgerTime's code (16K M-Network), bank 7 is at the end! I can't even get my old code to work anymore, and it was working before. Michael Rideout Quote Link to comment Share on other sites More sharing options...
supercat Posted October 1, 2005 Share Posted October 1, 2005 In other words, the first 4K of the binary is loading at $F000 through $FFFF, and the remaining 12K apparently isn't getting loaded at all-- which I guess is right, since the other banks aren't really there until they get switched in. Did you maybe forget the -g9 switch :-) Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted October 1, 2005 Author Share Posted October 1, 2005 Never mind, it seems to be a documentation problem. I mean, the z26 doc I'm looking at says that #9 is M-Network, but I have an old shortcut that uses -g7, and it runs my old 16K ROM correctly. But why does the z26 doc say that M-Network cart style is #9???? Offbeat Cartridge Formats (Bank Switching)------------------------------------------ z26 currently supports the following schemes: 1. Standard 8K bank switching. 2. Standard 16K bank switching. 3. Atari Super-Chip. 4. CBS Ram Plus. 5. Parker Brothers 8K. 6. TigerVision 8K. 7. Activision FE 8K. 8. Atari 32K. 9. M-Network 16K. 10. Pitfall II. 11. Starpath. 12. Megaboy. Support is automatic. z26 knows how to recognize cartridges. To override the default selection you may use the -g<n> command line switch. Press F1 to see the built-in help file for details. Michael Rideout Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted October 1, 2005 Author Share Posted October 1, 2005 Never mind, it seems to be a documentation problem. I mean, the z26 doc I'm looking at says that #9 is M-Network, but I have an old shortcut that uses -g7, and it runs my old 16K ROM correctly. But why does the z26 doc say that M-Network cart style is #9???? Offbeat Cartridge Formats (Bank Switching)------------------------------------------ z26 currently supports the following schemes: 1. Standard 8K bank switching. 2. Standard 16K bank switching. 3. Atari Super-Chip. 4. CBS Ram Plus. 5. Parker Brothers 8K. 6. TigerVision 8K. 7. Activision FE 8K. 8. Atari 32K. 9. M-Network 16K. 10. Pitfall II. 11. Starpath. 12. Megaboy. Support is automatic. z26 knows how to recognize cartridges. To override the default selection you may use the -g<n> command line switch. Press F1 to see the built-in help file for details. Michael Rideout 940820[/snapback] See, those numbers don't agree with these, so I got confused : -gN -- override game typeN=1 -- Commavid extra RAM N=2 -- 8K Superchip N=3 -- 8K Parker Brothers N=4 -- 8K Tigervision N=5 -- 8K Decathlon & Robot Tank N=6 -- 16K Superchip N=7 -- 16K M-Network N=8 -- 32K Superchip N=9 -- 8K Atari -- banks swapped N=10 -- Spectravideo Compumate N=11 -- 32K - 512K Extended Tigervision N=12 -- 8K UA Ltd. N=13 -- 64K Homestar Runner / Paul Slocum Quote Link to comment Share on other sites More sharing options...
