chrismiller75 Posted May 21, 2002 Share Posted May 21, 2002 Basic tech question here, but I know this is a common problem--my one of my paddles works find but the other is all jittery. Is there a fix for this or do I have to shell out for a new set? Quote Link to comment Share on other sites More sharing options...
Atari freak 1 Posted May 21, 2002 Share Posted May 21, 2002 All I think you have to do Is open it up and spray the pot (round metal thing) with electical cleaner. I'm not exactly sure if this is exactly what you do... mabye someone else here can give you a better discription of what you do. Quote Link to comment Share on other sites More sharing options...
Chris++ Posted May 21, 2002 Share Posted May 21, 2002 Remove the screws, take the controller apart really slowly, and then spray all of the round metal parts (especially the big one, the pot) with WD-40, available at any hardware store, Target, etc. Quote Link to comment Share on other sites More sharing options...
Atarinvader Posted May 21, 2002 Share Posted May 21, 2002 The best thing is to replace the pot' which I think is a 1K (but could be 10K, it'll say on it). Failing that I'd get hold of some Servisol (I use it for my crossfader on my mixer) and spray it into the pots case. Quote Link to comment Share on other sites More sharing options...
moycon Posted May 21, 2002 Share Posted May 21, 2002 Quit serving them coffee right before bedtime. Quote Link to comment Share on other sites More sharing options...
Atarinvader Posted May 21, 2002 Share Posted May 21, 2002 avoid WD40, it'll corode the pot... Quote Link to comment Share on other sites More sharing options...
Chris++ Posted May 21, 2002 Share Posted May 21, 2002 You're thinking of the grease remover. WD-40 is a brand, not a particular type of substance. WD-40 sells an Electrical Cleaning Spray that you can get almost anywhere, even at some Radio Shacks. The kind I'm thinking of has a red square on the can that reads, "Guaranteed not to corrode." (Not joking.) Of course, the Radio Shack guy might recommend something else, which will probably work just as well -- you got the main point, which is to spray the big metal round thing. Quote Link to comment Share on other sites More sharing options...
Atarinvader Posted May 21, 2002 Share Posted May 21, 2002 My bad. WD-40 do do an electrical contact spray which is the same as Servisol. Quote Link to comment Share on other sites More sharing options...
chrisr Posted May 22, 2002 Share Posted May 22, 2002 Radio shack tuner spray right on the pot. Works great like new. Chris Quote Link to comment Share on other sites More sharing options...
JCroniger Posted May 22, 2002 Share Posted May 22, 2002 I use the same as Chrisr. You could also disassemble the pot and clean it with rubbung alcohol and a q tip. This works great too. Quote Link to comment Share on other sites More sharing options...
chrismiller75 Posted May 22, 2002 Author Share Posted May 22, 2002 Sweet. Thanks playas! Quote Link to comment Share on other sites More sharing options...
Albert Posted May 24, 2002 Share Posted May 24, 2002 I was about to say, "Hey, this would be great for the Atari 2600 FAQ!" when I discovered it's already in there: quoteDirty paddles are a cause of great frustration. To clean them, buy a can of Cleaner/Degreaser (available at Radio Shack, catalog #64-4422), open up the paddles and spray directly into the pot area. Close them up, give them a few twists and they should be good as new. Silicon spray, WD40 and TV tuner can also be used, although there are warnings about possible gumming with WD40, and possible plastic rot with TV tuner. ..Al Quote Link to comment Share on other sites More sharing options...
