dr. kwack Posted January 27, 2006 Share Posted January 27, 2006 Back in the mid 90's I found an old program in BASIC for the C-64 that would enable your computer to capture sound samples via the tape drive. It was crude, but was fun to play around with. I believe it was an issue of Compute! or Compute's Gazette for the Commodore. Would this be possible on an 800XL? If so is there a similar program listing somewhere? Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 27, 2006 Share Posted January 27, 2006 The Atari has audio-in via the SIO port (which the cassette drive supplies an output to). The only problem is that the sound is just mixed with what POKEY/GTIA generates and there is no way to either sample or alter that sound. I'm fairly sure though that there are simple electonics projects around which hook up to the paddle input of a joystick port. It would be a simple case of scanning the paddles in fast POTGO mode, but the sample rate would not be so great since it takes 2 scanlines for the hardware to generate a value. Quote Link to comment Share on other sites More sharing options...
MaPa Posted January 27, 2006 Share Posted January 27, 2006 It is possible on ATARI. I remember we had such a small program. You just put audio cassete in tape drive start the program and it recorder around 20-30s of music to the memory and then replayed it back via POKEY (volume only mode of course). Quote Link to comment Share on other sites More sharing options...
dr. kwack Posted January 29, 2006 Author Share Posted January 29, 2006 MaPa, Was that a public domain program or something you had typed in? Just curious... Quote Link to comment Share on other sites More sharing options...
ijor Posted January 29, 2006 Share Posted January 29, 2006 There was no such a program, because as Rybags pointed out, the CPU has no access whatsoever to the audio input coming from the tape at the SIO connector. Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 29, 2006 Share Posted January 29, 2006 These days, such a program is not needed anyway. Even a '386 running a sound card can capture audio just fine. The Atari can only play 4-bit samples, but you can save memory and use 2-bit samples which are still distinguishable. There are also tricks to use multiple voices to get better than 4-bit samples. Writing a player program is fairly simple, just a couple of dozen lines of Assembler. Quote Link to comment Share on other sites More sharing options...
pseudografx Posted January 29, 2006 Share Posted January 29, 2006 There was no such a program, because as Rybags pointed out, the CPU has no access whatsoever to the audio input coming from the tape at the SIO connector. 1009063[/snapback] Actually, there was one, but I'm afraid it only worked with tape recorders that had TURBO expansion built in. Unfortunately I can't remember its name, but it was probably made by some Czech programmer. Quote Link to comment Share on other sites More sharing options...
MaPa Posted January 30, 2006 Share Posted January 30, 2006 Maybe TURBO expansion was needed I don't know. We just had that soft at home and I tried it a little, using some audio cassetes and replayed it back... IIRC I looked into the code of that small program and it used only 1bit sampling.. reads 0 or 1 from SIO and then replayed it back.. zero volume or full volume, nothing more. With 15,6kHz (change every line... 312x50) it's almost 2kB per second so as I said before, it played around 20+ sec of music. Quote Link to comment Share on other sites More sharing options...
pirx Posted January 30, 2006 Share Posted January 30, 2006 It would be a simple case of scanning the paddles in fast POTGO mode, but the sample rate would not be so great since it takes 2 scanlines for the hardware to generate a value. I did once such a device but it was sampling very low quality - with SKCTL bit 2 set the values returned by POTG0 were very inconsistent, I mean sound was hardly recognizable and close to random. With SKCTL bit 2 cleared the values were beautifully rendered, but 50/60Hz was way too low for any sound It is possible though, that my audio-to-resistance converter was just poorly designed. Quote Link to comment Share on other sites More sharing options...
