danwinslow Posted January 27, 2006 Share Posted January 27, 2006 Does anyone have any insight into what's needed generally to hook up the atari joystick ports to a block of digital IO pins on a small 386 PC board? These are just generic AD pins such as you find on small embedded controllers. They are read and written via memory mapped ports in the 386 io space. Just looking for general hints, unless you feel like being specific Quote Link to comment Share on other sites More sharing options...
djmips Posted January 27, 2006 Share Posted January 27, 2006 When you say AD does that mean Analog to Digital or is it a general purpose I/O pin (GPIO)? If it's a regular GPIO, what you need to do is to get the pinout of the connector from Google (Deathskull labs for instance) and then you need to wire it up so that each of the GPIO inputs is pulled high through a resistor and the switches in the joystick (left/right/up/down and fire) pull the input to ground. I've seen 47K and 100K resistors used as pullups on a 5V GPIO Here's some information http://arcadecontrols.com/arcade_sneskey.html#Amos http://users.erols.com/tiltonj/games/tech/2600cont.html Quote Link to comment Share on other sites More sharing options...
classics Posted January 30, 2006 Share Posted January 30, 2006 Assuming your pins can be configured as inputs with weak pullups, all you need to do is connect the common pin to ground and the other five pins to your I/O pins. When a switch is closed it will pull an input to ground (zero). Debounce in software. Steve Quote Link to comment Share on other sites More sharing options...
