Sikor Posted January 28, 2006 Share Posted January 28, 2006 XXL from Poland write few days ago new game for Atari XL/XE: SUDOKU (You can download it from here: http://atari8.info/stuff/sudoku.zip ). Good Luck with play it!!! Quote Link to comment Share on other sites More sharing options...
Cybernoid Posted January 28, 2006 Share Posted January 28, 2006 XXL from Poland write few days ago new game for Atari XL/XE: SUDOKU (You can download it from here: http://atari8.info/stuff/sudoku.zip ). Good Luck with play it!!! 1008473[/snapback] Good stuff! Thanks Quote Link to comment Share on other sites More sharing options...
classics Posted January 28, 2006 Share Posted January 28, 2006 How is this controlled? I was able to create a board full of numbers, but beyond that I cant seem to control anything. Steve Quote Link to comment Share on other sites More sharing options...
Sikor Posted January 28, 2006 Author Share Posted January 28, 2006 You must fill all blank pole with numbers. All must be from 1 to 9, different in all rows, columns and square. Use keyboard. It's simply to use. Quote Link to comment Share on other sites More sharing options...
classics Posted January 29, 2006 Share Posted January 29, 2006 Ok I was trying the joystick. Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted February 5, 2006 Share Posted February 5, 2006 Oha, *** complain modus off *** on friday (2nd february) I played this game with my girlfriend Debora. On the easiest level (was that beginner or easy?) it took us 28 minutes to complete a level. We did not have the motivation to play a harder game then... *** complain modus still off *** Looks like this game is really tough, even in the easiest modes. Errmm, what means the mode himself ?!? It appears to be the hardest mode... ?!? My first thought was, the Atari would play himself... alas, it did not... Anyway, here some "docs" for playing the game: 1) press Select to select the game difficulty... 2) press Option until it displays "create" 3) now press Start to start the game 4) press 1-9 to fill in numbers 1-9 (and -=+* to move around) 5) press Space to erase numbers (or simply overwrite them with a new number) finally 6) when you think you are done press Option again, until it displays "chekk" 7) then press Start to let the computer check your solution => if a "baarrp" sounds, then your solution is wrong, otherwise the program will create a new Sudoku screen, filled with new numbers... Target of the game: You have to fill in all 9 fields with numbers 1-9. Rule 1:Every single field must hold the numbers 1-9 once (and only once!). Rule 2: All nine fields form one big field and guess what: here you must also have the numbers 1-9 once (once vertically and once horizontically, meaning once in every row and column, but again only once!). Rule 3: some numbers are already given by the computer, you cannot change them (nor place them elsewhere)... Thus, type in the missing numbers and try to fit the rules (which is not so easy)... - Andreas Magenheimer. Quote Link to comment Share on other sites More sharing options...
