meltdown71835 Posted May 31, 2002 Share Posted May 31, 2002 I been researching the atari 2600 for programming purposes and I was wondering, how many kilobytes in a cartrige can an atari 2600 handle. I just starting researching this machine so I may not be correct in the wording. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
Paul Slocum Posted May 31, 2002 Share Posted May 31, 2002 It can address 2k. But some cartridges use bankswitching to get up to 8k, 16, or more. -Paul Quote Link to comment Share on other sites More sharing options...
meltdown71835 Posted May 31, 2002 Author Share Posted May 31, 2002 What is bank switching? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted May 31, 2002 Share Posted May 31, 2002 Changing where you put your money. j/k Bankswitching is a method of accessing more memory than the system is designed to access. Basically, it's like putting one playing card on top of another...both cards are still there, but you can only "see" one at a time. Quote Link to comment Share on other sites More sharing options...
Skatepunk60 Posted May 31, 2002 Share Posted May 31, 2002 nice explanation dude thanks Quote Link to comment Share on other sites More sharing options...
+bcombee Posted May 31, 2002 Share Posted May 31, 2002 Actually, the 2600 can directly address 4K of ROM. Bankswitching is done byhaving special memory addresses decoded by the cart hardware and used to select another bank of memory. It might look like 0x0000-0x0FFF bank 0 (2K) 0x1000-0x1FF8 bank 1 (almost 2K) 0x1FF9 - when accessed, select A into bank 1 0x1FFA - when accessed, select B into bank 1 0x1FFB - when accessed, select C into bank 1 0x1FFC - when accessed, select D into bank 1 etc... This gives a constant 2K of memory at the low end of the cart, and a switchable 2K at the top of the cart, depending on the last address in the small range that was accessed. [ 05-31-2002: Message edited by: Ben Combee ] Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted May 31, 2002 Share Posted May 31, 2002 You might add that you will be at the same point in memory in the new bank after it is swapped. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 31, 2002 Share Posted May 31, 2002 Yup, the address space is 4K. AFAIK the largest ROM inside a cart are 64K, but theoretical you could also do 1MB (256 banks) or even more. Quote Link to comment Share on other sites More sharing options...
Pitfall Harry Posted May 31, 2002 Share Posted May 31, 2002 Is it theoretically possible to jamb a miniaturized Nintendo 64 system board and one N64 cartridge game into an empty Atari 2600 cartridge case? The N64-in-an-Atari cart would have the standard 2600 cartridge circuit card interface so that it could be slotted into a standard VCS, but it would only use 2 lines for power, one line for RF out, a few more lines for Joystick port inputs, and it would bypass the rest of the 2600 console circuitry. It would be kinda cool to pop a 2600 cart into any old VCS and play something as visually dazzling as Legend of Zelda: Ocarina of Time. Ben Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted May 31, 2002 Share Posted May 31, 2002 I doubt it...all that conversion would take more power than the port handles. Quote Link to comment Share on other sites More sharing options...
sdrake Posted June 1, 2002 Share Posted June 1, 2002 quote: Originally posted by Pitfall Harry: Legend of Zelda: Ocarina of Time . Arrgg, no Zelda on Atari! Quote Link to comment Share on other sites More sharing options...
meltdown71835 Posted June 1, 2002 Author Share Posted June 1, 2002 Whats an better example of bank switching? I don't get what your saying. Is it like switching to 2k then to another 2k? Quote Link to comment Share on other sites More sharing options...
Paul Slocum Posted June 1, 2002 Share Posted June 1, 2002 Doing! I guess my brain is fried. The Atari can access not 2k but up to 4k. I suppose I should know that since I've been sitting here all day coding a 4k game! The following document explains bankswitching: Bankswitching Info -Paul Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted June 1, 2002 Share Posted June 1, 2002 I think that the best method of bankswitching (for beginners) would be the Robotank method...the other block is called up whenever you jump to a subroutine, and switched back automatically when the sub ends. That way, you never have to match up address locations when you switch. Quote Link to comment Share on other sites More sharing options...
Paul Slocum Posted June 1, 2002 Share Posted June 1, 2002 That's a neat method. I never read about that one before. But I don't think there's currently a way to make cartridges that support anything except F4, F6 and F8 bankswitching. So using Activision's FE method would limit distribution to emulators and Cuttle Cart. -Paul Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted June 1, 2002 Share Posted June 1, 2002 True, but it makes coding much easier for a beginner. Once the source code is fully working and understood it could pave the way to using the more common techniques. Quote Link to comment Share on other sites More sharing options...
