crash Posted January 31, 2006 Share Posted January 31, 2006 Greetings, I am looking for a program that can copy or backup files and subdirectories between Atari 8-bit drives. I have run across a program called ICD Flashback! which does this for Spartados directories, although for the moment I'm trying to use MyDOS since I know how to use it. CSS makes a program called Hard Drive Backup Pro, although I have no idea whether this will be compatible with MyIDE. Thanks! Quote Link to comment Share on other sites More sharing options...
atarixle Posted January 31, 2006 Share Posted January 31, 2006 (edited) May I offer: this is a program for Turbo-BASIC. Primary use is to Copy Files and Folders (between MyIDE 3.1 - Partitions), so I called this program Copy Files'n'Folders... Ofcause, this program can also be used without MyIDE. (before you copy something, please use the internal (s)etup) Mirko copyfnf.zip Edited January 31, 2006 by atarixle Quote Link to comment Share on other sites More sharing options...
crash Posted January 31, 2006 Author Share Posted January 31, 2006 (edited) May I offer: this is a program for Turbo-BASIC. Primary use is to Copy Files and Folders (between MyIDE 3.1 - Partitions), so I called this program Copy Files'n'Folders... Ofcause, this program can also be used without MyIDE. 1010243[/snapback] Great, I look forward to trying it! I also found another program called Atari Commander which may do the job. This seems to support either MyDOS or Spartdos subdirectories! It was fairly difficult to find so I'll post it here. There are two versions: AC16.ZIP - an ATR archive on a DOS II+/D 180k formatted image that I had a lot of trouble getting the files out of Atari Commander.zip - the files I extracted from the ATR Or if you prefer, the place where I found it: http://atari8.info/stuff/ac16.zip Cheers! Atari_Commander.zip ac16.zip Edited January 31, 2006 by crash Quote Link to comment Share on other sites More sharing options...
