Room 34 Posted June 2, 2002 Share Posted June 2, 2002 Does it have the spring-loaded latching door, the spring-loaded non-latching door, or no door at all over the chip? Are the silver-label carts manufactured differently from the earlier ones? I've taken apart a few black label carts and I figured out the spring mechanism. Quite ingenious, really. No wonder Atari didn't pay its game designers better... too much money went into manufacturing! Quote Link to comment Share on other sites More sharing options...
liquid_sky Posted June 2, 2002 Author Share Posted June 2, 2002 its got a spring loader .. pardon the crude ascii art. code: - - / / / O [ 06-02-2002: Message edited by: liquid_sky ] Quote Link to comment Share on other sites More sharing options...
Room 34 Posted June 2, 2002 Share Posted June 2, 2002 Gotcha. Those springs are tricky. What you need to do is line up the two pieces of the latching door in the bottom half of the cartridge. Then the two top hooks of the spring need to slide into a little groove in the inner piece of the latch. Once the spring is in the groove you'll know. You can push the slots on the end of the latching door (have you ever done this to clean the contacts? same thing), and it will slide as if the cart were all together. Once all of this is in place, slip the ROM chip back into its slot, then put the top of the cartridge back on. Sorry I can't explain this better. I have only done this a couple times and it was several weeks ago. I suppose I could videotape myself doing this and post a QuickTime. Let me know if this would be helpful. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted June 2, 2002 Share Posted June 2, 2002 That would'nt be a bad idea. Maybe for the AA archives, as well. Quote Link to comment Share on other sites More sharing options...
Room 34 Posted June 3, 2002 Share Posted June 3, 2002 quote: Originally posted by Nukey Shay: That would'nt be a bad idea. Maybe for the AA archives, as well. Great... well now I HAVE to do it. The question now is, which of my disassembled carts should I use for it? Take your pick from the ones with the label column marked "disassembled"! Quote Link to comment Share on other sites More sharing options...
liquid_sky Posted June 3, 2002 Author Share Posted June 3, 2002 hmm. hows about et to make sure the silver label are the same although im like 99% sure they are.. thanks for the instructions too but i didnt figrure out what to do yet.. i definatally am not a text based learner Quote Link to comment Share on other sites More sharing options...
Room 34 Posted June 3, 2002 Share Posted June 3, 2002 I had forgotten that I'd taken apart a silver label (E.T.). Yeah, they're the same... it's not an issue of the kind of label, just the way the latching mechanism on the end is designed. If it's the kind of game where you can't just push on the door with your finger and slide it back, then that's what we're dealing with. Quote Link to comment Share on other sites More sharing options...
Osbo Posted June 3, 2002 Share Posted June 3, 2002 well... i got two cents if i were u, i wouldn't worry about the dust cover osbo Quote Link to comment Share on other sites More sharing options...
Room 34 Posted June 3, 2002 Share Posted June 3, 2002 quote: Originally posted by osbo: if i were u, i wouldn't worry about the dust cover That brings up an interesting point: If the cartridge is the kind that has the latching dust cover, how the @#?$@! did a spider build a web inside it? And by the way, just out of curiosity, what game was it? [ 06-02-2002: Message edited by: room34 ] Quote Link to comment Share on other sites More sharing options...
liquid_sky Posted June 3, 2002 Author Share Posted June 3, 2002 I was having problems getting my cart to fit in my system so i took it apart.. egads there was a spider web in it! anyway.. now i cant figure out how to put the damn thing back togather!!! Quote Link to comment Share on other sites More sharing options...
Junie Posted June 3, 2002 Share Posted June 3, 2002 quote: Originally posted by osbo: well... i got two cents if i were u, i wouldn't worry about the dust cover osbo Just so you don't attempt this, as it will not work. The dust cover has latches that the Atari system needs for the game to actually plug into the Atari system. Without them the dust cover on the Atari system cartridge port will remain closed and the game will not work. Quote Link to comment Share on other sites More sharing options...
