KAZ Posted June 7, 2002 Share Posted June 7, 2002 OK, I think I found something useful for programming the Atari 2600. Ok, consider if I download DASM 2.02 for MSDOS. Then pretend for a second that I wrote the correct code into this program... How would I THEN make it into a usable format for an Atari emulator? I'm a newbie here, I'm really clueless. Quote Link to comment Share on other sites More sharing options...
Paul Slocum Posted June 7, 2002 Share Posted June 7, 2002 Say your source file is defender.asm, you would type (at the command line): "dasm defender.asm -f3 -odefender.bin" And it would produce defender.bin, which should work on an emulator. You can also use a one line batch file to make it a little easier. Save the following in a text file as ASM.BAT. "dasm %1.asm -f3 -o%1.bin" Then you'd just type: "asm defender" -Paul [ 06-06-2002: Message edited by: Smart Patrol ] Quote Link to comment Share on other sites More sharing options...
KAZ Posted June 7, 2002 Author Share Posted June 7, 2002 That's actually pretty clear, I almost understand that. If I knew more ms-dos, it would be even better... Thanks for the information, I will slowly try to continue to figure out the very basics of programming for the 2600... I'm further along in my knowledge than I was even last night.... Quote Link to comment Share on other sites More sharing options...
