+DarkLord Posted February 16, 2006 Share Posted February 16, 2006 Anyone have experience with actually installing and using the RSVE serial port mod? I'm looking for helpful suggestions, comments, hints, do's and don'ts, etc, etc,... Thanks! Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted February 22, 2006 Author Share Posted February 22, 2006 Dang, I was hoping someone had actually installed and was using it. :-( Oh well.... Quote Link to comment Share on other sites More sharing options...
krupkaj Posted February 22, 2006 Share Posted February 22, 2006 (edited) My friend installed it in his MEGA long time ago, but there were some troubles with it and I do not remember how it ended. So any info is welcome. Edited February 22, 2006 by krupkaj Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted February 22, 2006 Author Share Posted February 22, 2006 My friend installed it in his MEGA long time ago, but there were some troubles with it and I do not remember how it ended. So any info is welcome. 1022352[/snapback] I'd love to know what problems he had. Any chance of finding out? Thanks! Quote Link to comment Share on other sites More sharing options...
Gunstar Posted February 25, 2006 Share Posted February 25, 2006 Anyone have experience with actually installing and using the RSVE serial port mod? I'm looking for helpful suggestions, comments, hints, do's and don'ts, etc, etc,... Thanks! 1019164[/snapback] I don't even know what that is...an acrinim for? Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted February 26, 2006 Author Share Posted February 26, 2006 Anyone have experience with actually installing and using the RSVE serial port mod? I'm looking for helpful suggestions, comments, hints, do's and don'ts, etc, etc,... Thanks! 1019164[/snapback] I don't even know what that is...an acrinim for? 1024450[/snapback] Honestly, I don't really know what the letters "RSVE" stand for, but I know what it does. Its a hardware based serial port enhancer for ST computers. Using the RSVE mod and HSmodem you can get 38,400 speeds on standard STs, upwards of 115,200 on accelerated ones. Love to have a new one installed in my Mega ST... Quote Link to comment Share on other sites More sharing options...
belboz Posted February 26, 2006 Share Posted February 26, 2006 Atari Archive at Umich has had the RSVE stuff for quite awhile. The archive contains scematics, layour, docs, and jedec code for the GAL chip you need to program. The docs are in german and english. Each file starts off in German and then the bottom half is the english translation. http://www.umich.edu/~archive/atari/Utilit...xes/rsve_ge.lzh Seems pretty straightforward to hook up. You just need someone to program the GAL for you, if you don't have that capability. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted February 26, 2006 Author Share Posted February 26, 2006 Atari Archive at Umich has had the RSVE stuff for quite awhile. The archive contains scematics, layour, docs, and jedec code for the GAL chip you need to program. The docs are in german and english. Each file starts off in German and then the bottom half is the english translation. http://www.umich.edu/~archive/atari/Utilit...xes/rsve_ge.lzh Seems pretty straightforward to hook up. You just need someone to program the GAL for you, if you don't have that capability. 1024691[/snapback] Thats the catch - I have no idea how to program a GAL chip... Thanks for the reply. Quote Link to comment Share on other sites More sharing options...
belboz Posted February 26, 2006 Share Posted February 26, 2006 (edited) Sorry I didn't gather that the GAL was your problem from your posts. I thought you couldn't find any info on it. Regardless, the docs spec out the Gal chip you need to buy. A GAL16V8 Here is a blank GAL chip you can order. http://www.jameco.com/webapp/wcs/stores/se...productId=37452 Now you need a programmer device to program the chip with the code from the RSVE archive (the JED file). Here are a couple build your own GAL programmer projects. http://elm-chan.org/works/pgal/report_e.html http://www.geocities.com/ResearchTriangle/...70/galblast.htm You can buy them through many vendors like Digikey, Jameco, etc. The commercial ones usually run $200 - $300 though. Maybe someone one here has a PAL/GAL programmer and can help you. You could also reverse engineer the GAL and just build a circuit to do the same thing. I believe the docs describe the circuit, and there are programs that can decompile jedec code. Edited February 26, 2006 by belboz Quote Link to comment Share on other sites More sharing options...
krupkaj Posted February 26, 2006 Share Posted February 26, 2006 I can program the GAL chip for you. So in case you don't find anyone in your neighbourhood just pm me. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted February 26, 2006 Author Share Posted February 26, 2006 Sorry I didn't gather that the GAL was your problem from your posts. I thought you couldn't find any info on it. Regardless, the docs spec out the Gal chip you need to buy. A GAL16V8 Here is a blank GAL chip you can order. http://www.jameco.com/webapp/wcs/stores/se...productId=37452 Now you need a programmer device to program the chip with the code from the RSVE archive (the JED file). Here are a couple build your own GAL programmer projects. http://elm-chan.org/works/pgal/report_e.html http://www.geocities.com/ResearchTriangle/...70/galblast.htm You can buy them through many vendors like Digikey, Jameco, etc. The commercial ones usually run $200 - $300 though. Maybe someone one here has a PAL/GAL programmer and can help you. You could also reverse engineer the GAL and just build a circuit to do the same thing. I believe the docs describe the circuit, and there are programs that can decompile jedec code. 1024717[/snapback] Thanks for all that info. I'll save it for when I need it. :-) Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted February 26, 2006 Author Share Posted February 26, 2006 I can program the GAL chip for you. So in case you don't find anyone in your neighbourhood just pm me. 1024731[/snapback] Thanks! When I get started on it (never enough time), I'll keep you in mind for that part. Quote Link to comment Share on other sites More sharing options...
Greenious Posted April 24, 2006 Share Posted April 24, 2006 Anyone have experience with actually installing and using the RSVE serial port mod? I'm looking for helpful suggestions, comments, hints, do's and don'ts, etc, etc,... Thanks! Well, hi speed serial port mods are a dime a dozen for atari. And which one to use is up to each to decide on his own. But, it is an extremely simple mod. Why anyone would complicate it with a GAL is beyond me. Just get the MFP datasheet, and you'll see that all you need to do is feed a new RS-232 baseclock to it. (quartzoscillator 1.8432 MHz) since you can't get one that matches exactly what you want, you'll need a binary counter (74HC4040) to derive a speed that's 1/4 of the quartz I believe it was. And finally, you could use a nandgate or similar method to be able to switch back & forth if you want to be able to keep it "original". As someone already pointed out, more than 38.400 bps is hard to utilize without an accelerator. 1 Quote Link to comment Share on other sites More sharing options...
Xebec Posted May 9, 2022 Share Posted May 9, 2022 On 4/24/2006 at 5:03 PM, Greenious said: Well, hi speed serial port mods are a dime a dozen for atari. And which one to use is up to each to decide on his own. But, it is an extremely simple mod. Why anyone would complicate it with a GAL is beyond me. Just get the MFP datasheet, and you'll see that all you need to do is feed a new RS-232 baseclock to it. (quartzoscillator 1.8432 MHz) since you can't get one that matches exactly what you want, you'll need a binary counter (74HC4040) to derive a speed that's 1/4 of the quartz I believe it was. And finally, you could use a nandgate or similar method to be able to switch back & forth if you want to be able to keep it "original". As someone already pointed out, more than 38.400 bps is hard to utilize without an accelerator. I'm going a little off topic from my original ask - but it sounds like 38400 bps is stable even with the stock ST (68000@8 MHz), with the updated port? For faster you need both the updated port and an accelerator? Any chance you can link me to a 'preferred' serial port mod? I'd like to study and learn. Thanks! Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 10, 2022 Author Share Posted May 10, 2022 Yes, that is correct. The RSVE mod worked at higher speeds with a stock 8mhz ST... IIRC... Quote Link to comment Share on other sites More sharing options...
