Replacement Case
volkssuper
Where would one find a complete case?  Each 7800 i've purchased has come with some sort physical defect so i thought this would be the only fix. Also where would one find the large heatsink?
1024705[/snapback]
I have a spare shell kicking around in my workshop somewhere. A couple minor scuffs on the metal thing but aside form that it's minty, no cracks or chips or anyo fthat BS. Also You can use an old computer heat sink. All you need to do is drill a hole threw it and screw it on properly threw the whole in IC it's suposed to heat sink. You will also get less over heating also using a computer heat sink. For marathon gaming you can actually add a fan also, but thats a little more involved.
I have a 7800 that I spray painted all black around 1990. Now It still looks pretty good, but recently I've been wanting to get an original case to put the mobo in. I only did this because the metal part was getting all scratched up, so painting it solved that. Anyway, I regret that now, and would like to get an original case, if any are floating around?
Ya know... If AA can make clear cartridge shells, what about making clear system cases too?  :ponder:  :D
1025656[/snapback]
I'd love to see new cases for classic consoles made (it might be a great way to restore dusty, dirty, and sun-faded machines), but given the low demand compared to cartridge shells, I suspect that the tooling would be prohibitively expensive.
1025656[/snapback]
1025684[/snapback]
A big pre-paid pre-order might gets some action. I know I'd go for a clear 7800.
1025716[/snapback]
So would I ... maybe even with a new "20th Anniversary Edition" face plate, a reworked cartridge slot that doesn't have a problem with third-party cartridges, and pre-molded holes for mounting composite A/V jacks and standard AC adapter jacks for the modders among us. :) Edited by jaybird3rd
  • 3 weeks later...
