RSS Bot Posted March 21, 2006 Share Posted March 21, 2006 I now have the 3 fireballs bouncing around most of the playfield. I haven't rewritten the lower castle routines so the fireballs disappear while they traverse the lower 1/4th of the screen. I also made the left castles have a checkerboard pattern to make sure my updates to PF0 and PF1 are happening when they should. As you can tell by the purple castle, the original code wasn't quite up to spec There's also a few things odd with the fireballs X position 0 thru 4* are showing on the right side of the screenI can use X values 5-164* to compensate, so it's not a major problem There's a weird "hiccup" as the fireballs cross over pixel 8* from the left edge of the screenI'm using the positioning routine that Robert Mundschau posted to the Stella List a couple years back. I'll have to try another routine and compare the results. Another routine might fix X range as well. The fireballs are smaller than the one in WarlordsI'm using a 2LK along with the PHP trick as mentioned here at the MiniDig, so the ball/missiles span 2 scan lines. In Warlords the ball moves in 2 scan line increments, but is displayed over 4 scan lines. I doubt there's time to change it for all 3 fireballs so they'll be staying at 2 scan lines. * may not be exact pixels Anyhow it's time for bed. Here's the source and BIN if you care to take a look Medieval_Mayhem_2006_03_20.zip http://www.atariage.com/forums/index.php?a...&showentry=1360 Link to comment Share on other sites More sharing options...
