gtkakega Posted April 29, 2006 Share Posted April 29, 2006 I'm having problems formatting and writing DOS to disk using my upgraded Happy 1050 drive. I ran Happy 1050 ver 7 software and did enhanced diagnostics. I got a 'disk error 1764 8c'. Any ideas? Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 29, 2006 Share Posted April 29, 2006 (edited) 8C (140) is Serial Bus Input Framing Error. So, probably a hardware problem - or maybe just a bad SIO cable. Try it running at low I/O speed and with a different cable. Ed: also, isn't there a problem running some drive upgrades made for NTSC on PAL machines (due to different I/O rates you get with POKEY). Input Framing error means that the start/stop bit combinations aren't occurring properly (0 for start, 8 data bits, 1 for stop). Edited April 29, 2006 by Rybags Quote Link to comment Share on other sites More sharing options...
gtkakega Posted April 29, 2006 Author Share Posted April 29, 2006 8C (140) is Serial Bus Input Framing Error. So, probably a hardware problem - or maybe just a bad SIO cable. Try it running at low I/O speed and with a different cable. Ed: also, isn't there a problem running some drive upgrades made for NTSC on PAL machines (due to different I/O rates you get with POKEY). Input Framing error means that the start/stop bit combinations aren't occurring properly (0 for start, 8 data bits, 1 for stop). I did an RPM check and it reports 'too fast'. How do you tweak RPM? Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 29, 2006 Share Posted April 29, 2006 I think RPM is adjusted by a trimpot (with flat-head screwdriver). Never had to do it myself - someone else would probably have more info. Quote Link to comment Share on other sites More sharing options...
ijor Posted April 29, 2006 Share Posted April 29, 2006 Run the Happy Hi Speed Xfer diagnostics in the first place. This will tell you if you have any problems in the SIO chain. How you measured RPM? Most RPM programs will be fooled by the Happy track buffer. You must use the RPM measurement in the Happy software. Doesn't look you have an RPM problem. Which software gave you the "disk error" you mentioned? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted April 29, 2006 Share Posted April 29, 2006 Adjusting RPM is described in this thread: http://www.atariage.com/forums/index.php?showtopic=25783 There's also a small Basic program to use if your DOS lacks an RPM monitor. Quote Link to comment Share on other sites More sharing options...
gtkakega Posted April 29, 2006 Author Share Posted April 29, 2006 Run the Happy Hi Speed Xfer diagnostics in the first place. This will tell you if you have any problems in the SIO chain. How you measured RPM? Most RPM programs will be fooled by the Happy track buffer. You must use the RPM measurement in the Happy software. Doesn't look you have an RPM problem. Which software gave you the "disk error" you mentioned? I'm running Happy ver 7 software diagnostics. I ran X) Hi Speed Xfer diagnostics and it passed. I ran R) RPM test and it reported 294 RPM too fast. I since adjusted RPM to 287 is just fine. I ran W) Read/Write test and it passed. I ran E) Enhancement diagnostics and RAM test #1 passed, but RAM test #2 failed. Disk error 1764 8C. ??? Quote Link to comment Share on other sites More sharing options...
ijor Posted April 30, 2006 Share Posted April 30, 2006 That’s quite strange. I’m not sure the problem is actually in the RAM. As far as I can see, that error message is produced when activating the test program inside the drive. SIO detected a serial framing error at this point. It is not a disk error despite what the error message says. I don’t know what could produce this error. RAM can’t be that bad, or otherwise the drive won’t even boot, it will fail the self-test that includes a full RAM test on power up. The RAM might have a subtle problem that shows up only on this test. But then, the problem might be anything else (including a corrupted diagnostic disk), and not necessarily the RAM. Are you still having write problems after correcting the RPM? Quote Link to comment Share on other sites More sharing options...
