Arcadenut Posted April 8, 2002 Share Posted April 8, 2002 It contains several bug fixes. 04/07/2002 Version 2.0.1.7 - Fixed a bug with Drag and Drop operation of the Media/Hardware Roots. It would only open the last list under those when dragged. - Fixed a bug that would not allow "Close All" if only one media list and one hardware lists were open. - Fixed a bug in the Collection Explorer that some times didn't populate properly on Windows ME and lower. - Fixed a bug in the Field Order dialog that caused the check marks to become out of sync when moving an item down. - Fixed a Spelling Error on the Compress List Confirmation dialog. - Fixed a bug where pasting items in would not update the appearance of the Tab to show it was modified. - Fixed a bug that would not sort data if the data in the sort column was updated. - Fixed a bug that was reintroduced with 2.0 that didn't sort the alphabetic fields correctly (Upper/Lower Case issue). - Fixed a bug that would not enable the Save Button if you changed the List Properties. - Changed the Add Item From List Dialog to use a status bar at the bottom in order to fix a problem with Windows XP and Themes. - Added a Master List for the Sega Saturn, thanks to Ben Turner! Download from here: Cart Commander Quote Link to comment Share on other sites More sharing options...
