Goochman Posted May 12, 2006 Share Posted May 12, 2006 I know there isnt much I can do with my Mega2 - however I got a NE2000 compat Cartidge ethernet cart a few years back and was able to 'ftp' content to my windows box - Id like to see it do something more - Is there anything on this site that I could run on my Mega 2 to get a basic browser working? http://www.ettnet.se/~dlanor/sting/html/file.htm Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 12, 2006 Share Posted May 12, 2006 I know there isnt much I can do with my Mega2 - however I got a NE2000 compat Cartidge ethernet cart a few years back and was able to 'ftp' content to my windows box - Id like to see it do something more - Is there anything on this site that I could run on my Mega 2 to get a basic browser working? http://www.ettnet.se/~dlanor/sting/html/file.htm Hi. If you've got the EtherNEC, and you've got it working, then both of these work: CAB (brower) Newsie (newsgroups and mail) I had my EtherNEC hooked up to the Mega ST that runs my BBS for awhile and it worked fine with STing there. I could browse web pages with CAB (Crystal Atari Browser), read newsgroups and send/receive e-mail with Newsie. Quote Link to comment Share on other sites More sharing options...
jens Posted May 12, 2006 Share Posted May 12, 2006 AtarICQ and AtarIRC will work as well. You will need wdialog in your auto-folder to use any of those programs. Have fun. Quote Link to comment Share on other sites More sharing options...
Goochman Posted May 12, 2006 Author Share Posted May 12, 2006 So here is where I am confused - looking at the STinG page there are a variety of modules and such - which ones are required to install to run CAB and AtarICQ? Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 12, 2006 Share Posted May 12, 2006 So here is where I am confused - looking at the STinG page there are a variety of modules and such - which ones are required to install to run CAB and AtarICQ? Okay, I'll do the best I can to help. Here is the software I've got and where (all of this is on the C drive): AUTO (folder) STING.INF STING.PRT STING.PRG WDIALOG.PRG (I also use HSMODEMs software in the AUTO folder) CPX (folder) STING.CPX STNGPORT.CPX STING (folder) cache.dns default.cfg ether.sty masque.sty route.tab tools cen_plep.sty docs lcltlk.sty midi.sty serial.stx udp.stx cen_plip.sty enec.mif logfile.xxx resolve.stx sting.prt update.txt default.bak enec.stx masque.stx route.bak tcp.stx xfers TOOLS and DOCS are folders inside the STING folder. Well, I think thats about it for that. You will still have to adjust some files, like DEFAULT.CFG. Here is what mine looks like: #---------------------------------------------------------------------------- # File name: DEFAULT.CFG (for STinG) Revision date: 2000.07.05 #---------------------------------------------------------------------------- # # First we have settings used by STinG and its distributed CPX and STX : # ====================================================================== # (Read STING.HYP for info on how to use them to improve performance.) # # Used by the STinG kernel : # ALLOCMEM = 100000 # ACTIVATE = TRUE THREADING = 10 FRAG_TTL = 60 # # # Used for ICMP protocol : # ICMP_GMT = -60 ICMP_AD = 10 ICMP_FLAG = 0 # # # Used for UDP protocol : # UDP_PORT = 1024 UDP_ICMP = 1 # # # Used for TCP protocol : # TCP_PORT = 1024 MSS = 1460 RCV_WND = 10000 DEF_RTT = 1500 DEF_TTL = 64 TCP_ICMP = 1 # # # Used by the DNS resolver : # # Note that the first one of these three will not normally be used. # It will only be used when an address consisting of a single word # is used in a URI. The DOMAIN value is then appended to complete # the URI as needed for the nameserver request packets. # (I still recommend using full URIs instead, to avoid confusion.) # DOMAIN = sting.org DNS_CACHE = 64 DNS_SAVE = TRUE # # # The three following are not really used by the kernel anymore, as the # dialer redefines these for each dialup, as they can vary when you have # more than one ISP dial script. They should be defined here anyway, # with the values you normally use online, as some offline clients may # expect to find them, and also for use in local networking. # USERNAME = darklord HOSTNAME = darkforce4.org FULLNAME = Ronald J. Hall # # # The one following is also redefined by the dialer, and you only need to # define it here if you use a local network, so all machines in that net # can find the nameserver (the dialer only defines it on one machine). # Note that the value of NAMESERVER variables should always be a numeric # IP address, since another nameserver would be needed to resolve a URI. # You can specify more than one address, separated by ", " . # (eg: "NAMESERVER = 193.45.240.2, 193.45.240.4") # NAMESERVER = 192.168.0.1 # # # Here starts the stuff used by external clients and servers : # ============================================================ # # Used by the Dialer : # -------------------- # # The setting below is not used by the dialer itself, but by any other # client in a local network that wishes to contact the dialer which is # resident on a machine equipped with a modem. (By UDP command packets.) # If you have no local network, leave it as it is, since that is an IP # address reserved for the local machine. # DIALER = 127.0.0.1 # # # The setting below is used by the dialer, but only if you have chosen # to activate the DIAL.SCR setting to use a dialup batch file. The path # specified below will then be used to find the batch file. # LOGIN_BATCH = C:\DIALER\LOGIN.BAT # # # Used by mailers : # ----------------- # EMAIL = dark_lord@charter.net SMTP_HOST = smtp.charter.net MAILER = pop.charter.net # POP_HOST = news.charter.net POP_USERNAME= dark_lord POP_PASSWORD= XXXXXX (your password goes here) # # # Used by TIME and DAYTIME clients and servers: # --------------------------------------------- # (Values used by me, in Sweden in the year 2000.) # TIME_ZONE = +60 TIME_SUMMER = 03.26.10.29 TIME_SERVER = time.demon.co.uk # # # Used by MIDI_EMU server (for some netgames) : # --------------------------------------------- # MIDI_EMU_OUT = next_IP_in_emulated_Midi_ring # # # Add more here as/when needed by other clients and servers # that you install in your system. (Read their docs...) # #---------------------------------------------------------------------------- # End of file: DEFAULT.CFG #---------------------------------------------------------------------------- I hope this helps get you started. If you have more questions, just post them. Someone will try their best to help you. Quote Link to comment Share on other sites More sharing options...
Goochman Posted May 13, 2006 Author Share Posted May 13, 2006 Cool - thanks - I need to drag out the Mega and give this a try again Quote Link to comment Share on other sites More sharing options...
jens Posted May 16, 2006 Share Posted May 16, 2006 (edited) You should download cab.ovl from Oliviérs webpages to be able to use cab via network. Cab usually just can use modems and this ovl (or another one - there are several floating around) will tell it what network is. In the sting default.cfg you will just have to change the line NAMESERVER = 192.168.0.1 to the ip that your router has. In route.tab you have to set a '#' before each line which is not needed, that is in your case every line except 0.0.0.0(tab)0.0.0.0(tab)EtherNet(tab)192.168.0.1 Make sure you set those tabs as tabs and not as spaces, not every text editor can do this. I suggest using qed or luna; 7up can't do this. At the moment I'm working on my german webpage which contains an explanation to get an atari to the web via ethernec, but so far I did not put the software packet needed into the downloads section. If you drop me a mail with your routers' ip address (and two or three words about you being atariage user I can send you back the files needed and if you wish already set up. If you use ICQ feel free to contact me. Edited May 16, 2006 by jens Quote Link to comment Share on other sites More sharing options...
Goochman Posted May 17, 2006 Author Share Posted May 17, 2006 Thanks jens - I will put an email out to you when I get back home later this week Quote Link to comment Share on other sites More sharing options...
Goochman Posted June 15, 2006 Author Share Posted June 15, 2006 Ok I finally got my Mega 2 out and loaded up the files Jens sent me. I think things are installed ok however I have the following issues: 1. When I try to fill out the MAC address in the STing control panel I get an error saying 'Ooops Cannot Change MAC' or something like that and the values go to ff:ff:ff:ff:ff 2. I unLZH'd the CAB stuff - it created a CAB directory and there is a CAB.OVL file there - how do I launch CAB? Quote Link to comment Share on other sites More sharing options...
Paolo Posted June 15, 2006 Share Posted June 15, 2006 The CAB.OVL is just the overlay that CAB needs to 'link' with StiNG. So you need to get CAB Quote Link to comment Share on other sites More sharing options...
Goochman Posted June 15, 2006 Author Share Posted June 15, 2006 Sorry for my ignorance - so I get CAB outside of theLZH file i decompressed that contained a CAB folder with an ENGLISH and GERMAN folder under it? Where do I get CAB then? Quote Link to comment Share on other sites More sharing options...
jens Posted June 15, 2006 Share Posted June 15, 2006 (edited) After reading and answering your pms I now looked in here. You can get Cab from Application Systems Heidelberg (ASH) in Germany. They have an older Freeware Version and the actual Cab 2.8 demo. Cab Download Page Edited June 15, 2006 by jens Quote Link to comment Share on other sites More sharing options...
